Philips Hue White and Color Ambiance A60 E27 Twin Pack
Quicklinx: D5M1WS00 Mfr#: 929001257363
Type: Light bulb
Compatible With: Alexa, Google Assistant, IFTTT, Nest + 1 more
£70.83 ex VAT
£84.99 inc VAT
Get started with the Philips Hue white and color ambiance starter kit and turn on your imagination. Discover the amazing things you can do with white and colored light, with even richer colors for better scene setting.
  • Be creative with colors
    Play with light and choose from millions of colors to instantly change the look and atmosphere of your room. Set the scene effortlessly with one touch of a button. Use a favorite photo and relive that special moment with splashes of light. Save your favorite light settings and recall them whenever you want with the tap of a finger.
  • Create your ambiance
    Set the right ambiance for any moment and decorate your home with warm to cool light. Enjoy different styles throughout the year, no matter if it's the crisp light reminding you of a spring breeze, the warm light of a summer sun, or the ice cool daylight of winter.
  • Sync with music and movies
    Extend your TV viewing experience to the whole room or sync light to your favorite music and see how light reacts to the rhythm.
  • Wake up and go to sleep
    Philips Hue will help get you out of bed the way you like it, helping you start your day feeling refreshed. The light brightness increases gradually mimicking the effect of sunrise and helps you wake up naturally, instead of being woken up by the loud sound of an alarm clock. Start your day, the right way. In the evening, the relaxing warm light helps you to unwind, relax and prepare your body for a good night's sleep.
Philips Hue White and color ambiance - LED light bulb
Light Bulb Type
LED light bulb
Packaged Quantity
2 (specifications are for single item)
Socket Type
E27
Wattage
10 W
Light Bulb Energy Efficiency Class
A+
Colour of Illumination
16 million colours
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Packaged Quantity
Light Bulb
LED light bulb
Socket Type
E27
Wattage
10 W
A+
16 million colours
Remote controlled
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Platform
Hue
Warranty
2 years
Diameter
62 mm
Length
110 mm
-10 °C
45 °C
Type: Light bulb
Compatible With: IFTTT
Compatible With: Nest
Compatible With: Siri
Brand: Philips
Price Range Ex VAT: 50 - 100
