Philips Hue White Ambiance B22 Twin Pack
Quicklinx: FFSDWS00 Mfr#: 929002217102
Select:
  • B22
Light your home smarter with Philips Hue
Imagine being able to turn off all your lights with one click. Discover the magic of transforming an entire room from study to home cinema with one tap. Or maybe use your lights to make it seem like you are home when actually you’re not. And when you are home, choose the right light setting to help you concentrate better or relax after a tough day.
  • Control lights with your voice
    Philips Hue works with Amazon Alexa and the Google Assistant when paired with a compatible Google Nest or Amazon Echo device. Simple voice commands allow you to control multiple lights in a room, or just a single lamp.
  • Set the right mood with warm to cool white light
    These bulbs and light fixtures offer different shades of warm to cool white light. With complete dimmability from bright to low nightlights, you can tune your lights to the perfect shade and brightness of light for your daily needs.
  • Get the perfect light recipes for your daily activities
    Make your day easier and more pleasant with four pre-set light recipes handcrafted especially for your daily tasks: Energize, Concentrate, Read and Relax. The two cool-toned scenes, Energize and Concentrate, help you get going in the morning or keep your focus, while the warmer scenes of Read and Relax help support comfortable reading or calm a busy mind.
Philips Hue White ambiance - LED light bulb - B22 - cool daylight/warm white light (pack of 2)
Light Source Type
LED light bulb
Packaged Quantity
2 (specifications are for single item)
Socket Type
B22
Energy Efficiency Class
A+
Colour of Illumination
Cool daylight/warm white light
Dimmable
Intelligent Assistant
Cortana, Google Assistant, Alexa
Platform
Apple HomeKit, Hue
Communications Technology
Bluetooth, Zigbee
Packaged Quantity
Light Source
LED light bulb
Socket Type
B22
A+
Dimmable
Upgradable firmware, instant full light, Android compatible, iOS compatible, voice control, app-controlled
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Apple HomeKit, Hue
Bluetooth, Zigbee
Package
Hanging box
72 g
140 mm x 70 mm x 165 mm / 224 g
