Philips Hue White 9.5W A60 B22 2-Pack
Quicklinx: GPXVWS00 Mfr#: 929002469302
Hurry, only 2 left in stock!
£24.99 ex VAT
£29.98 inc VAT
These two B22 smart LED bulbs offer just right amount of soft white smart light. With a brightness equivalent to a traditional 75 W bulb, these bulbs are best used to light areas of the living room or kitchen.
  • Dimmable soft white light
    These bulbs and light fixtures offer shades of warm white light. With complete dimmability from bright to low nightlights, you can tune your lights to the perfect brightness of light for your daily needs.
  • Control up to 10 lights with the Bluetooth app
    With the Hue Bluetooth app, you can control your Hue smart lights in a single room of your home. Add up to 10 smart lights and control them all with just the touch of a button on your mobile device.
  • Control lights with your voice
    Philips Hue works with voice assistants when paired with a compatible device. Simple voice commands allow you to control multiple lights in a room, or just a single lamp.
Philips Hue White - LED light bulb - shape: A60 - B22 - 9.5 W - soft warm white light - 2700 K - white (pack of 2)
Recommended For
Kitchen, living room
Light Source Type
LED light bulb
Packaged Quantity
2 (specifications are for single item)
White
Shape
A60
Socket Type
B22
Wattage
9.5 W
Wattage Equivalent
75 W
Energy Efficiency Class
F
Colour of Illumination
Soft warm white light
Colour Temperature
2700 K
Luminous Power
1100 lumens
Dimmable
Intelligent Assistant
Cortana, Google Assistant, Alexa, Apple HomeKit
Communications Technology
Bluetooth, Zigbee
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Packaged Quantity
Recommended For
Android compatible, iOS compatible
Light Source
LED light bulb
Shape
A60
Socket Type
B22
Wattage
9.5 W
Wattage Equivalent
75 W
F
Energy Consumption per 1000h
9.5 kWh
Power Factor
0.5
Colour Temperature
2700 K
Colour Rendering Index
80
Luminous Power
1100 lumens
Dimmable
Lifetime
25000 hours
Switch Cycles
50000
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Power Consumption Stand by
0.41 Watt
Internet of Things (IoT)
Bluetooth, Zigbee
Body Colour
White
Package
Box
Warranty
2 years / 30 days return
Diameter
61 mm
Length
110 mm
14.6 cm x 7.2 cm x 17.4 cm / 270 g
-20 °C
45 °C
Type: Light bulb
Compatible With: Cortana
Compatible With: Alexa
Compatible With: Apple HomeKit
Brand: Philips
