Get the classic look of vintage bulbs in a smaller size with two Filament candle bulbs, offering coiled inner filaments and E14 bases. These bulbs are perfect for small fixtures where you want vintage style with a modern twist.
- Philips Hue White - LED filament light bulb - shape: candle - clear finish - E14 - 4.5 W - soft warm white light - 2100 K (pack of 2)
- Light Source Type
- Packaged Quantity
- 2 (specifications are for single item)
- Shape
- Candle
- Bulb Finish
- Clear
- Socket Type
- E14
- Wattage
- 4.5 W
- Wattage Equivalent
- 28 W
- Energy Efficiency Class
- G
- Colour of Illumination
- Soft warm white light
- Colour Temperature
- 2100 K
- Luminous Power
- 300 lumens
- Beam Angle
- 360 degree(s)
- Dimmable
- Intelligent Assistant
- Siri, Cortana, Google Assistant, Alexa - indirect
- Platform
- Apple HomeKit, Hue
- Communications Technology
- Bluetooth, Zigbee
- Voltage Required
- AC 220 - 240 V
- Frequency Required
- 50/60 Hz
- Packaged Quantity
Light Source
- Shape
- Candle
- Bulb Finish
- Clear
- Socket Type
- E14
- Wattage
- 4.5 W
- 28 W
- G
- Energy Consumption per 1000h
- 5 kWh
- Power Factor
- 0.6
- 2100 K
- Colour Rendering Index
- 80
- Luminous Power
- 300 lumens
- Beam Angle
- 360 degree(s)
- Dimmable
- Lifetime
- 15000 hours
- Switch Cycles
- 50000
- Upgradable firmware, instant full light, Android compatible, iOS compatible, voice control, remote controlled, app-controlled, coiled filament
Power Requirements
- Voltage Required
- AC 220 - 240 V
- 50/60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Bluetooth, Zigbee
- Voice Controlled
- Indirect
- Package
- Hanging box
- Warranty
- 2 years
- Diameter
- 39 mm
- Length
- 117 mm
- Shipping Dimensions (WxDxH) / Weight
- 7.2 cm x 8.6 cm x 17.4 cm / 102 g
- -20 °C
- 45 °C
