Philips Hue White ambiance can help you to fall asleep and wake up gently. It can energize you and help you to concentrate, read and relax. Set the right ambiance with a range of white light, from cool daylight to relaxing warm white light.
Control it your way
Control your lights from your smartphone or tablet, or add switches to your system to activate your lights. -
Create your ambiance with warm white to cool daylight
Set the right ambiance for any moment and decorate your home with warm to cool white light. Enjoy different styles throughout the year, no matter if it's the crisp white light reminding you of a spring breeze, the warm white light of a summer sun, or the ice cool daylight of winter. -
Energize yourself
Skip your morning coffee and get ready for the day with cool, bright white daylight that helps to energize your body and mind. Perfect for those moments when your batteries are running low and you need a kickstart.
- Philips Hue White ambiance Starter Kit - wireless lighting set - LED light bulb x 3 - shape: A60 - E27 - 8 W - warm white to cool daylight - 2200-6500 K
- Product Type
- Wireless lighting set
- Energy Label QR Code URL
- Https://eprel.ec.europa.eu/qr/406179
- Light Source Type
- 3 x LED light bulb
- Supported Light Bulbs Qty
- 50
- Dimmer
- Shape
- A60
- Socket Type
- E27
- Wattage
- 8 W
- Wattage Equivalent
- 75 W
- Energy Efficiency Class
- F
- Colour of Illumination
- Warm white to cool daylight
- Colour Temperature
- 2200-6500 K
- Luminous Power
- 806 lumens
- Intelligent Assistant
- Cortana, Google Assistant, Alexa
- Platform
- Apple HomeKit, Google Home, Hue
- Communications Technology
- Bluetooth, Zigbee
- Voltage Required
- AC 220 - 240 V
- Product Type
- 50
- Dimmer
- Android compatible, iOS compatible, 16 million changeable colours, app-controlled, lighting schedules, power on/off timer, voice control
Light Source
- Shape
- A60
- Socket Type
- E27
- Wattage
- 8 W
- 75 W
- F
- Energy Consumption per 1000h
- 8 kWh
- Power Factor
- 0.5
- 2200-6500 K
- Luminous Power
- 806 lumens
- Lifetime
- 25000 hours
- Switch Cycles
- 50000
- Instant full light
Power Requirements
- Voltage Required
- AC 220 - 240 V
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Compatible Application
- Philips Hue App
- Bluetooth, Zigbee
- Included Accessories
- Power adapter, network cable, Hue switch, Hue bridge
- Package
- Box
- Warranty
- 2 years
- 549 g
- Dimensions & Weight Details
- Light bulb - width: 60 mm x depth: 60 mm x height: 110 mm - 72 g , Wireless bridge height: 2.6 cm , Dimmer switch - width: 3.5 cm x depth: 1.1 cm x height: 9.2 cm - 37 g , Wall plate - width: 7 cm x depth: 0.6 cm x height: 7.6 cm
- Shipping Dimensions (WxDxH) / Weight
- 21.9 cm x 17.6 cm x 14 cm / 1.01 kg
- -20 °C
- 45 °C
