Philips Hue Tap Dial Switch
Quicklinx: H4SFWS00 Mfr#: 929003500101
Type: Wireless light switch
Compatible With: Alexa, Google Assistant
10 In Stock
£33.33 ex VAT
£39.99 inc VAT
Control up to three Rooms or a Zone with each individual button of the Tap dial switch, available in black or white. Turn the dial to dim and brighten the lights. Mount it to the wall, place it on a magnetic surface, or use it as a remote control.
Control your way
Philips Hue accessories are versatile: set up, program it and use exactly how you want.
Expertly designed, easy to use
Expertly designed, easy to use Wireless and effortlessly installed, smart light switches were made to make smart lighting simple.
Personalise in the Hue app
Easily select preset light scenes or customise your switch's settings to match the time of day.
One-click control
No need to navigate through the app - just one push controls your lights.
Dim and brighten instantly
Our smart switches install in seconds without the need to rewire, letting you dim and brighten your lights straight out of the box.
  • Convenient, customizable control
    Handy smart switches give you immediate control of your lights throughout your home.
  • Always in control
    Control your entire smart lighting system from anywhere in your home - without your phone or tablet. Effortlessly switch the room's light scene or get the right light based on the time of day. Made to be used by anyone, Philips Hue smart switches are the simplest way to control your lights.
  • Expertly designed, easy to use
  • One-click control
  • Dim and brighten instantly
    The smart switch installs in seconds without the need to rewire, letting you dim and brighten your lights straight out of the box.
Philips Hue Tap - light switch - ZigBee - white
Light switch
Placing / Mounting
Wall-mounting, freestanding
Functions
Dimming, light control
Power Source
Internet of Things (IoT) Platform
Hue
Wireless - ZigBee
Frequency Band
2400 - 2483.5 Mhz
White
6 cm x 6 cm x 2 cm
Light switch
Functions
Power Source
Placing / Mounting
Wireless - ZigBee
Frequency Band
2400 - 2483.5 Mhz
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Communications Type
Product-to-product
Communications Technology
Zigbee
CR2023
Battery Included
Wall plate
Product Material
Plastic
White
Warranty
IP20
6 cm
6 cm
2 cm
70 g
Dimensions & Weight Details
Wall plate: 80 mm x 6 mm x 80 mm
Shipping Width
7.2 cm
Shipping Depth
8.6 cm
Shipping Height
17.4 cm
Shipping Weight
170 g
0 - 80% (non-condensing)
Brand: Philips
