Recall your four favorite scenes anywhere in your home at the touch of a button. Use Philips Hue Tap as a remote control and turn all your lights off at the same time. Completely wireless and works without batteries, for your comfort.
Recall your favorite scenes
With the Tap switch you can recall 4 different preset light scenes or switch lights on/off by pressing a button. Use the app to setup your personal scenes or scenes that are created by lighting designers. You can use the Tap switch without opening the Philips Hue App and even when your Wi-Fi is disconnected. -
Mount or use remotely
Mount the Tap switch anywhere with the included mounting plate, or detach it and carry it with you as you move through your home. Set the right mood for every moment of the day. -
Use as a remote control
You can also use Philips Hue tap switch as a remote control for your comfort. -
Powered by your touch
The Tap switch is powered by kinetic energy, which means that when you press the light switch you generate sufficient energy to control your smart lights.
- Philips Hue Tap - light switch - ZigBee - black
- Product Type
- Light switch
- Placing / Mounting
- Wall-mounting, freestanding
- Functions
- Dimming, light control
- Internet of Things (IoT) Platform
- Hue
- Connectivity
- Wireless - ZigBee
- Frequency Band
- 2400 - 2483.5 Mhz
- Black
- 2-year warranty
- 6 cm x 6 cm x 2 cm
- Product Type
- Light switch
- Functions
- Connectivity Technology
- Wireless - ZigBee
- Frequency Band
- 2400 - 2483.5 Mhz
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Hue
- Communications Type
- Product-to-product
- Communications Technology
- Zigbee
- Form Factor
- CR2023
- Battery Included
- Included Accessories
- Wall plate
- Product Material
- Plastic
- Black
- Warranty
- 2-year warranty
- IP20
- 6 cm
- 6 cm
- 2 cm
- 70 g
- Dimensions & Weight Details
- Wall plate: 80 mm x 6 mm x 80 mm
- Shipping Width
- 7.2 cm
- Shipping Depth
- 8.6 cm
- Shipping Height
- 17.4 cm
- Shipping Weight
- 170 g
- 0 °C
- 40 °C
- 0 - 80% (non-condensing)
