Philips Hue Tap Dial Switch - Black
Quicklinx: HWZHWS00 Mfr#: 929003500201
11 In Stock
£33.36 ex VAT
£40.03 inc VAT
Recall your four favorite scenes anywhere in your home at the touch of a button. Use Philips Hue Tap as a remote control and turn all your lights off at the same time. Completely wireless and works without batteries, for your comfort.
  • Recall your favorite scenes
    With the Tap switch you can recall 4 different preset light scenes or switch lights on/off by pressing a button. Use the app to setup your personal scenes or scenes that are created by lighting designers. You can use the Tap switch without opening the Philips Hue App and even when your Wi-Fi is disconnected.
  • Mount or use remotely
    Mount the Tap switch anywhere with the included mounting plate, or detach it and carry it with you as you move through your home. Set the right mood for every moment of the day.
  • Use as a remote control
    You can also use Philips Hue tap switch as a remote control for your comfort.
  • Powered by your touch
    The Tap switch is powered by kinetic energy, which means that when you press the light switch you generate sufficient energy to control your smart lights.
Philips Hue Tap - light switch - ZigBee - black
Light switch
Placing / Mounting
Wall-mounting, freestanding
Functions
Dimming, light control
Internet of Things (IoT) Platform
Hue
Wireless - ZigBee
Frequency Band
2400 - 2483.5 Mhz
6 cm x 6 cm x 2 cm
Light switch
Functions
Placing / Mounting
Wireless - ZigBee
Frequency Band
2400 - 2483.5 Mhz
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Communications Type
Product-to-product
Communications Technology
Zigbee
CR2023
Battery Included
Wall plate
Product Material
Plastic
Warranty
IP20
6 cm
6 cm
2 cm
70 g
Dimensions & Weight Details
Wall plate: 80 mm x 6 mm x 80 mm
Shipping Width
7.2 cm
Shipping Depth
8.6 cm
Shipping Height
17.4 cm
Shipping Weight
170 g
0 - 80% (non-condensing)
Brand: Philips
