Philips Hue Solo lightstrip - 5m
Quicklinx: HT6ZWS00 Mfr#: 929003817003
Type: Light strip
Compatible With: Alexa, Google Assistant
Select:
£66.66 ex VAT
£79.99 inc VAT
Transform your home and mood with a brilliant lighting experience. Easy to install, the 10-metre Philips Hue Solo lightstrip provides 1700 lumens of stunning light output to make your home brighter. Illuminated by RGBWW LEDs, this lightstrip creates pure colour and pure white light. It's designed with safety in mind. Allowing you to interact with the lightstrip comfortably. Every Philips Hue lightstrip comes with a 2-year guarantee.
Control lights with your voice
When connected to the Hue Bridge, you can pair your lights with Alexa, Apple HomeKit, and the Google Assistant and control your lights using just your voice. Simple voice commands let you turn your lights on and off, dim or brighten your lights, and even set a light scene.
Personalise settings in the app
Make your entertainment media experience your own. Use the app to change your light settings, such as the brightness and speed of the effects, as well as define default start-up settings.
Control it your way
Connect your Philips Hue lights with the bridge and start discovering the endless possibilities. Control your lights from your smartphone or tablet via the Philips Hue app, or add switches to your system to activate your lights. Set timers, notifications, alarms and more for the full Philips Hue experience. Philips Hue even works with Amazon Alexa, Apple Homekit and Google Home to allow you to control your lights with your voice.
Add smart switches, sensors and more
Enhance your Hue smart lighting system with various accessories, including smart dimmer switches and motion sensors. Connect up to 12 accessories on one Hue Bridge and fully automate your home.
  • Versatile control options
    With both Bluetooth and Zigbee communications technology, this Philips Hue White and Color Ambiance light strip offers flexible control options. Easily adjust settings via the Philips Hue App or connect it to a Philips Hue Bridge for expanded features.
  • Dynamic lighting
    Experience the full spectrum of color and white light with the built-in LED lamp, capable of producing up to 1700 lumens. The color rendering index of 80 ensures vivid colors and natural whites, enhancing any space with dynamic lighting.
  • Long-lasting and energy-efficient
    Designed for durability and efficiency, the light strip boasts a lifetime of 25,000 hours and a low power consumption of 20 W, making it an eco-friendly choice for long-term illumination.
  • Smart home integration
    Compatible with Alexa and Google Assistant, this light strip integrates seamlessly into your smart home setup, allowing for voice-activated control and creating the perfect ambiance effortlessly.
  • Flexible installation
    The cuttable and flexible design, paired with a 1.5 m cable, ensures easy installation in a variety of settings. Whether accentuating architectural features or adding a splash of color to a room, this light strip adapts to your creative needs.
Philips Hue White and Color Ambiance Solo - light strip - LED - 20 W - multicolour/white light - white
Light strip
Light Source Type
LED
Cable Length
1.5 m
White
Wattage
20 W
Colour of Illumination
Multicolour/white light
Luminous Power
1700 lumens
Dimmable
Intelligent Assistant
Platform
Hue
Communications Technology
Zigbee, Bluetooth
AC 220 - 240 V
Light strip
Cable Length
1.5 m
Cuttable, flexible, app-controlled, controlled via Bluetooth
Light Source
LED
Built-in LED Lamp
Wattage
20 W
Colour Rendering Index
80
Luminous Power
1700 lumens
Dimmable
Lifetime
25000 hours
Power Requirements
AC 220 - 240 V
Power Consumption Stand by
0.5 Watt
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Compatible Application
Philips Hue App
Supported Host Device Platform
Android, iOS
Zigbee, Bluetooth
Product Material
Silicone
Body Colour
White
Power adapter
IP20
Warranty
2 years
1.4 cm
0.45 cm
Length
5 m
450 g
18.3 cm x 7.6 cm x 18.7 cm / 590 g
-20 °C
Type: Light strip
Brand: Philips
