Transform your home and mood with a brilliant lighting experience. Easy to install, the 10-metre Philips Hue Solo lightstrip provides 1700 lumens of stunning light output to make your home brighter. Illuminated by RGBWW LEDs, this lightstrip creates pure colour and pure white light. It's designed with safety in mind. Allowing you to interact with the lightstrip comfortably. Every Philips Hue lightstrip comes with a 2-year guarantee.
Versatile control options
With both Bluetooth and Zigbee communications technology, this Philips Hue Solo light strip offers flexible control options. Easily manage lighting effects using the Philips Hue App or integrate it into your smart home setup for voice control with Alexa and Google Assistant. -
Dynamic lighting experience
Create the perfect ambiance in any room with multicolor and white light options. The dimmable feature and a color rendering index of 80 ensure vivid colors and adjustable brightness to match your mood or activity. -
Efficient and durable
Designed with a built-in LED lamp that boasts a lifetime of 25,000 hours and a luminous power of 1700 lumens, this light strip provides an efficient lighting solution. Its 20 W wattage and low standby power consumption of 0.5 watts make it an energy-conscious choice. -
Flexible installation
Thanks to its cuttable and flexible design, the Philips Hue Solo light strip can be easily customized to fit any space. The silicone material and IP20 compliance ensure durability and protection against solid objects larger than 12.5 mm. -
Smart home integration
Compatible with the Philips Hue Bridge, this light strip can be seamlessly integrated into your existing Philips Hue ecosystem. Expand your smart lighting setup with ease and enjoy advanced features like out-of-home control and setting light schedules.
- Philips Hue Solo - light strip - LED - 20 W - multicolour/white light - white
- Product Type
- Light strip
- Light Source Type
- LED
- Cable Length
- 1.5 m
- White
- Wattage
- 20 W
- Colour of Illumination
- Multicolour/white light
- Luminous Power
- 1700 lumens
- Dimmable
- Intelligent Assistant
- Google Assistant, Alexa
- Platform
- Hue
- Communications Technology
- Bluetooth, Zigbee
- Voltage Required
- AC 220 - 240 V
- Product Type
- Light strip
- Cable Length
- 1.5 m
- Flexible, controlled via Bluetooth, cuttable, app-controlled
Light Source
- LED
- Built-in LED Lamp
- Wattage
- 20 W
- Colour Rendering Index
- 80
- Luminous Power
- 1700 lumens
- Dimmable
- Lifetime
- 25000 hours
Power Requirements
- Voltage Required
- AC 220 - 240 V
- Power Consumption Stand by
- 0.5 Watt
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Hue
- Compatible Application
- Philips Hue App
- Supported Host Device Platform
- iOS, Android
- Bluetooth, Zigbee
- Product Material
- Silicone
- Body Colour
- White
- Included Accessories
- Power adapter
- IP20
- Warranty
- 2 years
- 14 mm
- 4.5 mm
- Length
- 10000 mm
- 690 g
- Shipping Dimensions (WxDxH) / Weight
- 18.3 cm x 9 cm x 18.7 cm / 840 g
- -20 °C
- 40 °C
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
HT70 051236 Condition: Customer return - item has been opened but is in excellent condition |
£41.61 |
Ref:
HT70 051237 Condition: Customer return - item has been opened but is in excellent condition |
£49.18 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
