Philips Hue Solo lightstrip - 10m
Quicklinx: HT70WS00 Mfr#: 929003817103
Type: Light strip
Compatible With: Alexa, Google Assistant
Select:
26 In Stock
£99.99 ex VAT
£119.98 inc VAT
Transform your home and mood with a brilliant lighting experience. Easy to install, the 10-metre Philips Hue Solo lightstrip provides 1700 lumens of stunning light output to make your home brighter. Illuminated by RGBWW LEDs, this lightstrip creates pure colour and pure white light. It's designed with safety in mind. Allowing you to interact with the lightstrip comfortably. Every Philips Hue lightstrip comes with a 2-year guarantee.
  • Versatile control options
    With both Bluetooth and Zigbee communications technology, this Philips Hue Solo light strip offers flexible control options. Easily manage lighting effects using the Philips Hue App or integrate it into your smart home setup for voice control with Alexa and Google Assistant.
  • Dynamic lighting experience
    Create the perfect ambiance in any room with multicolor and white light options. The dimmable feature and a color rendering index of 80 ensure vivid colors and adjustable brightness to match your mood or activity.
  • Efficient and durable
    Designed with a built-in LED lamp that boasts a lifetime of 25,000 hours and a luminous power of 1700 lumens, this light strip provides an efficient lighting solution. Its 20 W wattage and low standby power consumption of 0.5 watts make it an energy-conscious choice.
  • Flexible installation
    Thanks to its cuttable and flexible design, the Philips Hue Solo light strip can be easily customized to fit any space. The silicone material and IP20 compliance ensure durability and protection against solid objects larger than 12.5 mm.
  • Smart home integration
    Compatible with the Philips Hue Bridge, this light strip can be seamlessly integrated into your existing Philips Hue ecosystem. Expand your smart lighting setup with ease and enjoy advanced features like out-of-home control and setting light schedules.
Philips Hue Solo - light strip - LED - 20 W - multicolour/white light - white
Light strip
Light Source Type
LED
Cable Length
1.5 m
White
Wattage
20 W
Colour of Illumination
Multicolour/white light
Luminous Power
1700 lumens
Dimmable
Intelligent Assistant
Google Assistant, Alexa
Platform
Hue
Communications Technology
Bluetooth, Zigbee
AC 220 - 240 V
Light strip
Cable Length
1.5 m
Flexible, controlled via Bluetooth, cuttable, app-controlled
Light Source
LED
Built-in LED Lamp
Wattage
20 W
Colour Rendering Index
80
Luminous Power
1700 lumens
Dimmable
Lifetime
25000 hours
Power Requirements
AC 220 - 240 V
Power Consumption Stand by
0.5 Watt
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Compatible Application
Philips Hue App
Supported Host Device Platform
iOS, Android
Bluetooth, Zigbee
Product Material
Silicone
Body Colour
White
Power adapter
IP20
Warranty
2 years
14 mm
4.5 mm
Length
10000 mm
690 g
18.3 cm x 9 cm x 18.7 cm / 840 g
-20 °C
Type: Light strip
Brand: Philips
