Philips Hue Smart Plug
Quicklinx: GSPVWS00 Mfr#: 929003050701
Select:
  • Single
Inconspicuous, compact design
This small, unassuming accessory allows you to turn any light – even one in which you can’t place a Hue bulb – into a smart light so that you can control it via the Hue app or voice. Use Bluetooth for instant light control or connect to the Hue Bridge to unlock more features.
  • Bluetooth enabled
  • Hue Bridge enabled
  • Add any light to your Hue system
  • Instant control via Bluetooth
  • Control with app or voice*
  • Add Hue Bridge to unlock more
  • Inconspicuous, compact design
    The Philips Hue Smart plug was designed to blend into any environment.
  • Create a more versatile home
    Small, white and with a subtle design, the Smart plug allows you to add any light to your Hue system without any added wires or hassle.
Philips Hue - smart plug - Bluetooth, ZigBee Light Link - white
Smart plug
Power Source
Power socket
Intelligent Assistant
Google Assistant, Alexa
Wireless - Bluetooth, ZigBee Light Link
Frequency Band
2.4 - 2.4835 GHz
White
6 cm x 6 cm x 6.4 cm
Smart plug
Power Source
Power socket
Frequency Band
2.4 - 2.4835 GHz
Internet of Things (IoT)
White
Warranty
IP20
6 cm
6 cm
6.4 cm
113 g
Shipping Width
7.2 cm
Shipping Depth
7.2 cm
Shipping Height
14 cm
Shipping Weight
173 g
5 - 95% (non-condensing)
