Smart lights, smart speaker, smart thermostat – what else could you possibly need? How about two Philips Hue smart plugs? Once you plug them in, you’ll be able to control anything connected to them using the handy smartphone app. And they don’t need a hub or anything – they have Bluetooth built-in. Want a lamp to turn on when it gets dark? Set the automatic timer and they’ll do just that. Plus, if you’ve got an Amazon Alexa smart speaker, you can sync them up and use voice commands. How’s that for hands-free?
- Smart plug - control home electricals from your phone
- Turn devices on and off, no matter where you are
- Ready-to-use via Bluetooth - no hub required
- Use the Philips Hue app to control devices on-the-go
- Works with Alexa and Google Assistant
Inconspicuous, compact design
The Philips Hue Smart plug was designed to blend into any environment. -
Create a more versatile home
Small, white and with a subtle design, the Smart plug allows you to add any light to your Hue system without any added wires or hassle. -
Instant control via Bluetooth
Use Bluetooth for instant light control or connect to the Hue Bridge to unlock more features.
- Philips Hue - smart plug - Bluetooth - white (pack of 2)
- Product Type
- Smart plug
- Packaged Quantity
- 2 (specifications are for single item)
- Functions
- Light control
- Power Source
- Power socket
- Connectivity
- Wireless - Bluetooth
- Frequency Band
- 2404 - 2483.5 MHz
- White
- Localisation
- United Kingdom
- 2-year warranty
- 6 cm x 6 cm x 6.4 cm
- Packaged Quantity
- Product Type
- Smart plug
- Functions
- Light control
- Power Source
- Power socket
- Connectivity Technology
- Frequency Band
- 2404 - 2483.5 MHz
- Up to 3120 Watt
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Product Material
- Synthetic
- White
- Localisation
- United Kingdom
- Voltage Required
- AC 220-240 V
- Warranty
- 2-year warranty
- IP20
- 6 cm
- 6 cm
- 6.4 cm
- 110 g
