Philips Hue Smart Plug 2-Pack
Quicklinx: H57KWS00 Mfr#: 919313000072
Type: Smart plug
Compatible With: Alexa, Google Assistant, Siri
Select:
More than 50 In Stock
£49.99 ex VAT
£59.98 inc VAT
Express delivery Order within the next 20 hours for delivery on Friday
Smart lights, smart speaker, smart thermostat – what else could you possibly need? How about two Philips Hue smart plugs? Once you plug them in, you’ll be able to control anything connected to them using the handy smartphone app. And they don’t need a hub or anything – they have Bluetooth built-in. Want a lamp to turn on when it gets dark? Set the automatic timer and they’ll do just that. Plus, if you’ve got an Amazon Alexa smart speaker, you can sync them up and use voice commands. How’s that for hands-free?
  • Smart plug - control home electricals from your phone
  • Turn devices on and off, no matter where you are
  • Ready-to-use via Bluetooth - no hub required
  • Use the Philips Hue app to control devices on-the-go
  • Works with Alexa and Google Assistant
  • Inconspicuous, compact design
    The Philips Hue Smart plug was designed to blend into any environment.
  • Create a more versatile home
    Small, white and with a subtle design, the Smart plug allows you to add any light to your Hue system without any added wires or hassle.
  • Instant control via Bluetooth
    Use Bluetooth for instant light control or connect to the Hue Bridge to unlock more features.
Philips Hue - smart plug - Bluetooth - white (pack of 2)
Smart plug
Packaged Quantity
2 (specifications are for single item)
Functions
Light control
Power Source
Power socket
Wireless - Bluetooth
Frequency Band
2404 - 2483.5 MHz
White
United Kingdom
6 cm x 6 cm x 6.4 cm
Packaged Quantity
Smart plug
Functions
Light control
Power Source
Power socket
Frequency Band
2404 - 2483.5 MHz
Up to 3120 Watt
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Product Material
Synthetic
White
United Kingdom
AC 220-240 V
Warranty
IP20
6 cm
6 cm
6.4 cm
110 g
Type: Smart plug
Compatible With: Siri
Brand: Philips
