Philips Hue Resonate WCA Wall Light Black 2-Pack
Quicklinx: H4XGWS00 Mfr#: 919313000059
Type: Wall lamp
Compatible With: Alexa, Google Assistant, Siri
Hurry, only 2 left in stock!
£233.33 ex VAT
£279.99 inc VAT
Directing its light in triangular light effects both up and down, the Resonate wall light in black allows you to illuminate your porches and patios with elegant, colourful light.
  • 16 million colors
    Create the perfect ambience for your home with over 16 million colors.
  • Unwind with warm to cool white light
    Extend your evenings with Philips Hue outdoor lighting. Set the right ambience on your patio, balcony or porch and relax. From the warm white light of a summer sun to the ice cool daylight of winter: you can enjoy any shade of white light to fit your mood throughout the year.
  • Come home to a house filled with light
    Set your Philips Hue app to recognize when you're almost home. Before you even step out of your car or walk up the path, your selected smart lights turn on automatically.
  • Unique architectural light shapes
    Create an architectural focal point with outdoor fixtures that offer razor-sharp, triangular light effects against any wall or surface.
  • High-quality aluminum and superior synthetics
    The products are made specifically for outdoor use, manufactured from high-quality materials to ensure excellent performance in outdoor conditions, as well as smart use of materials to optimize radio frequency.
  • Weather-proof (IP44)
    This Philips Hue outdoor fixture is specially designed for use in outdoor environments and has undergone rigorous tests to ensure its performance.
Philips Hue White and Color Ambiance Resonate - wall lamp - LED x 2 - 8 W - 16 million colours/warm to cool white light - 2000-6500 K - black (pack of 2)
Wall lamp
Recommended For
Garden, patio
Light Source Type
2 x LED
Packaged Quantity
2 (specifications are for single item)
Dimmer
Wattage
8 W
Colour of Illumination
Colour Temperature
2000-6500 K
Luminous Power
1180 lumens
Intelligent Assistant
Siri, Google Assistant, Alexa - indirect
Platform
Hue
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Packaged Quantity
Wall lamp
Recommended For
Garden, patio
Supported Light Bulb Wattage
8 W
Dimmer
Waterproof
Weatherproof, outdoor usage, splashproof, protection class I, Android compatible, iOS compatible, app-controlled
Light Source
2 x LED
Built-in LED Lamp
Wattage
8 W
Colour Temperature
2000-6500 K
Colour Rendering Index
80
Luminous Power
1180 lumens
Lifetime
25000 hours
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Compatible Application
Philips Hue App
Voice Controlled
Indirect
Product Material
Die-cast aluminium
Body Colour
IP44
Warranty
2 years
9.3 cm
12 cm
18 cm
950 g
Type: Wall lamp
Compatible With: Siri
Brand: Philips
