Directing its light in triangular light effects both up and down, the Resonate wall light in black allows you to illuminate your porches and patios with elegant, colourful light.
                16 million colorsCreate the perfect ambience for your home with over 16 million colors.
                Unwind with warm to cool white lightExtend your evenings with Philips Hue outdoor lighting. Set the right ambience on your patio, balcony or porch and relax. From the warm white light of a summer sun to the ice cool daylight of winter: you can enjoy any shade of white light to fit your mood throughout the year.
                Come home to a house filled with lightSet your Philips Hue app to recognize when you're almost home. Before you even step out of your car or walk up the path, your selected smart lights turn on automatically.
                Unique architectural light shapesCreate an architectural focal point with outdoor fixtures that offer razor-sharp, triangular light effects against any wall or surface.
                High-quality aluminum and superior syntheticsThe products are made specifically for outdoor use, manufactured from high-quality materials to ensure excellent performance in outdoor conditions, as well as smart use of materials to optimize radio frequency.
                Weather-proof (IP44)This Philips Hue outdoor fixture is specially designed for use in outdoor environments and has undergone rigorous tests to ensure its performance.
- Philips Hue White and Color Ambiance Resonate - wall lamp - LED x 2 - 8 W - 16 million colours/warm to cool white light - 2000-6500 K - black (pack of 2)
- Product Type
- Wall lamp
- Recommended For
- Garden, patio
- Light Source Type
- 2 x LED
- Packaged Quantity
- 2 (specifications are for single item)
- Dimmer
- Black
- Wattage
- 8 W
- Colour of Illumination
- Colour Temperature
- 2000-6500 K
- Luminous Power
- 1180 lumens
- Intelligent Assistant
- Siri, Google Assistant, Alexa - indirect
- Platform
- Hue
- Voltage Required
- AC 220 - 240 V
- Frequency Required
- 50 - 60 Hz
- Packaged Quantity
- Product Type
- Wall lamp
- Recommended For
- Garden, patio
- Supported Light Bulb Wattage
- 8 W
- Dimmer
- Waterproof
- Weatherproof, outdoor usage, splashproof, protection class I, Android compatible, iOS compatible, app-controlled
Light Source
- 2 x LED
- Built-in LED Lamp
- Wattage
- 8 W
- 2000-6500 K
- Colour Rendering Index
- 80
- Luminous Power
- 1180 lumens
- Lifetime
- 25000 hours
Power Requirements
- Voltage Required
- AC 220 - 240 V
- 50 - 60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Hue
- Compatible Application
- Philips Hue App
- Voice Controlled
- Indirect
- Product Material
- Die-cast aluminium
- Body Colour
- Black
- IP44
- Warranty
- 2 years
- 9.3 cm
- 12 cm
- 18 cm
- 950 g
