Philips Hue Play Twin Pack and Ext.
Quicklinx: GQSQWS00 Mfr#: 919213000341
Type: Light strip kit
Compatible With: Siri, Alexa, Google Assistant, IFTTT
Hurry, only 1 left in stock!
£141.66 ex VAT
£169.99 inc VAT
Express delivery Order within the next 9 hours for delivery tomorrow
Upgrade your movie room with this Philips Hue Play double pack. The lights connect to your phone and flood your walls with over 16 million shades of colour – a perfect backdrop for the biggest blockbusters. If you want to set the mood for date night, you can even adjust the brightness, or you can set a timer for them to go off after a few hours in case you accidentally doze off. And each light lasts for around 25,000 hours, so you won’t have to buy new ones anytime soon.
  • Decorate with ambient smart lights
    Transform the atmosphere of your home with just the touch of a button. Use over 16 million colors and 50,000 shades of cool to warm white light to create special moments, set the mood for a party, or simply wind down for the evening.
  • Create your ambiance with warm white to cool daylight
    Set the right ambiance for any moment and decorate your home with warm to cool white light. Enjoy different styles throughout the year, whether it's the crisp white light reminding you of a spring breeze, the warm white light of a summer sun or the ice-cool daylight of winter.
  • Amp your entertainment with smart lighting
    Immerse yourself in your movie, game, or music with the magic of light. With millions of colors from which to choose and countless lighting options, you can turn any living room into a private cinema - all you need to bring is the popcorn!
  • Connect 3 Hue Play light bars with 1 plug
    Hue Play won't add to a jumble of wires behind your TV or hog too many outlets. You can connect three Hue Play smart light bars to the same power supply unit, leaving you more than enough room for all your other devices.
  • Control it your way
    Connect your Philips Hue lights with the bridge and start discovering the endless possibilities. Control your lights from your smartphone or tablet via the Philips Hue app, or add switches to your system to activate your lights. Set timers, notifications, alarms and more for the full Philips Hue experience.
Philips Hue White and Color Ambiance Play - light strip kit - LED x 3 - total: 42 W - 16 million colours/tunable white - 2000-6500 K - black (pack of 2)
Light strip kit
Light Source Type
3 x LED
Packaged Quantity
2 (specifications are for single item)
Total Wattage
42 W
Dimmer
Colour of Illumination
Colour Temperature
2000-6500 K
Luminous Power
530 lumens
Platform
Hue
Frequency Required
50 - 60 Hz
Packaged Quantity
Light strip kit
Total Wattage
42 W
Dimmer
Hue Sync technology
Light Source
3 x LED
Colour Temperature
2000-6500 K
Colour Rendering Index
80
Luminous Power
530 lumens
Lifetime
10 years
Power Requirements
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub
Required
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Product Material
Synthetics
Body Colour
Power supply
IP20
Warranty
2 years
4.4 cm
25.3 cm
3.6 cm
20 cm x 30 cm x 10 cm / 1.69 kg
Compatible With: Alexa
Compatible With: IFTTT
Brand: Philips
