Whether it’s blockbusters or dramatic game backdrops, don’t just enjoy those cinematic scenes on your screen, be surrounded by them with the Philips Hue Play light bar. It’ll flood your room with colour, 16 million shades to be precise. You get to decide how bright those hues are since there’s a dimmer switch on the app, and from there you can even use the timer to turn the lights on automatically. Why not schedule them for when you arrive home and enjoy a nice warm welcome each time? Don’t worry about it ending any time soon either, the standalone light has a 25,000-hour lifespan.
Please note, to use the Philips Hue light bulb you’ll need a Philips Bridge (included). You’ll also need to download the free Philips Hue app, which is compatible with all iOS and Android devices.
- Smart lightbar can be wirelessly controlled
- White and coloured bulb – choose from 16 million shades
- Standalone light with a 25,000 hour lifespan
- Schedule a timer to turn lights on automatically
- Dim the brightness to match your mood
                Sync with films, TV programs, music and gamesGet dynamic surround lighting right in your living room.
                Set the mood with lightCreate a color ambiance that perfectly matches your mood and home interior.
                Place it anywhereUse the included stands to set the light bars upright or mount them to the TV - or just lay them flat!
                Small but mightyThe Play light bar enhances any entertainment set-up.
- Philips Hue White and Color Ambiance Play - light bar - LED - 13.2 W - 16 million colours - 2000-6500 K - black (pack of 2)
- Product Type
- Light bar
- Recommended For
- Living room
- Light Source Type
- LED
- Packaged Quantity
- 2 (specifications are for single item)
- Dimmer
- Black
- Wattage
- 13.2 W
- Colour of Illumination
- Colour Temperature
- 2000-6500 K
- Luminous Power
- 500 lumens
- Intelligent Assistant
- Google Assistant, Alexa - indirect
- Platform
- SmartThings
- Communications Technology
- Zigbee
- Packaged Quantity
- Product Type
- Light bar
- Recommended For
- Living room
- Dimmer
- Expandable, music sync, timer function
Light Source
- LED
- Built-in LED Lamp
- Wattage
- 13.2 W
- 2000-6500 K
- Luminous Power
- 500 lumens
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Included
- Hub Compatibility
- Philips Hue Bridge
- Platform
- SmartThings
- Supported Host Device Platform
- iOS, Android
- Zigbee
- Voice Controlled
- Indirect
- Body Colour
- Black
- Included Accessories
- Stand
- IP20
- Warranty
- 2 years
- 4.4 cm
- 3.6 cm
- Length
- 25.3 cm
- 710 g
