Philips Hue Play Light Bar Twin Pack - Black
Quicklinx: GNWZWS00 Mfr#: 915005733901
Type: Light bar
Compatible With: IFTTT, Siri, Alexa, Google Assistant
22 In Stock
£83.33 ex VAT
£99.99 inc VAT
Create a wash of colourful smart light with the sleek design of the Play light bar in black. This Play light bar, which includes a power supply that can connect up to three light bars, can be stood upright, laid horizontally, or placed onto the back of your TV with the included mounts.
Display Hue Play your way
The Philips Hue Play light bar can be mounted to a wall or TV, laid flat on any surface or stood upright. A versatile smart light, it makes the perfect accent piece for any living room, entertainment space or media room.
Decorate with ambient smart lights
Transform the atmosphere of your home with just the touch of a button. Use over 16 million colours and 50,000 shades of cool to warm white light to create special moments, set the mood for a party, or simply wind down for the evening.
Mount behind your TV
Mount the Philips Hue Play smart light bar behind your screen using the included clips and double-sided tape to instantly create beautiful backlighting in the colour of your choice.
Create your ambience with warm white to cool daylight
Set the right ambience for any moment and decorate your home with warm to cool white light. Enjoy different styles throughout the year, whether it's the crisp white light reminding you of a spring breeze, the warm white light of a summer sun or the ice-cool daylight of winter. Connection with the Philips Hue bridge is required for this functionality.
Amplify your entertainment with smart lighting
Immerse yourself in your movie, game, or music with the magic of light. With millions of colours from which to choose and countless lighting options, you can turn any living room into a private cinema – all you need to bring is the popcorn!
Connect 3 Hue Play light bars with 1 plug
Hue Play won't add to a jumble of wires behind your TV or hog too many outlets. You can connect three Hue Play smart light bars to the same power supply unit, leaving you more than enough room for all your other devices.
Control it your way
Connect your Philips Hue lights with the bridge and start discovering the endless possibilities. Control your lights from your smartphone or tablet via the Philips Hue app, or add switches to your system to activate your lights. Set timers, notifications, alarms and more for the full Philips Hue experience. Philips Hue even works with Amazon Alexa, Siri and Google Home to allow you to control your lights with your voice.
Full control from a smart device with the Hue bridge
Connect your Philips Hue lights with the bridge to unlock the endless possibilities of the system.
  • Personalize your playtime
    Get dynamic surround lighting right in your living room. Build a battle station that amplifies every in-game effect. Create a color ambiance that perfectly matches your mood and home interior.
  • Control your way
    Use a Hue app, your voice or smart accessories to control your set-up.
  • Place, mount anywhere
    Use the included stands to set the light bars upright or mount them to the TV - or just lay them flat!
  • 1 power supply, 3 light bars
    Plug up to three light bars into a single socket with the included power supply.
Philips Hue White and Color Ambiance Play - light bar - LED - 16 million colours - black (pack of 2)
Light bar
Light Source Type
LED
Packaged Quantity
2 (specifications are for single item)
Dimmer
Colour of Illumination
16 million colours
Luminous Power
530 lumens
Platform
Hue
AC 110 - 240 V
Frequency Required
50 - 60 Hz
Packaged Quantity
Light bar
Dimmer
Protection class III
Light Source
LED
Built-in LED Lamp
16 million colours
Luminous Power
530 lumens
Lifetime
25000 hours
Power Requirements
AC 110 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Platform
Hue
Product Material
Synthetics
Body Colour
Power adapter
IP20
Warranty
2 years
4.4 cm
25.3 cm
3.6 cm
710 g
20.2 cm x 29.9 cm x 9.6 cm / 1.07 kg
Type: Light bar
Compatible With: Siri
Compatible With: Alexa
Brand: Philips
