Add to your lighting setup with the Phillips Hue Play Light Bar Extension Kit. Because you can connect up to three Hue Play Light Bars together using just one plug, you won't need to find an extra plug socket for this Extension Kit - simply connect it to your current Hue Play (sold separately).
Decorate with ambient smart lights
Transform the atmosphere of your home with just the touch of a button. Use over 16 million colours and 50,000 shades of cool to warm white light to create special moments, set the mood for a party, or simply wind down for the evening.
Amplify your entertainment with smart lighting
Immerse yourself in your movie, game, or music with the magic of light. With millions of colours from which to choose and countless lighting options, you can turn any living room into a private cinema ยท all you need to bring is the popcorn!
Display Hue Play your way
The Philips Hue Play light bar can be mounted to a wall or TV, laid flat on any surface, or stood upright. A versatile smart light, it makes the perfect accent piece for any living room, entertainment space, or media room.
Mount behind your TV
Mount the Philips Hue Play smart light bar behind your screen using the included clips and double-sided tape to instantly create beautiful backlighting in the colour of your choice.
Connect to your Hue Bridge for full smart lighting control
This product requires a connection to the Hue Bridge to unlock the full smart control and features. Control your lights using the Philips Hue app, set timers, routines, add or remove lights and more. *Hue Bridge sold separately
Please note:
Some features require the Philips Hue Bridge (sold separately).
This extension kit doesn't include a mains adapter, it is powered via a Hue Play Light Bar (sold separately).
The Philips Hue Play light bar can be mounted to a wall or TV, laid flat on any surface or stood upright. A versatile smart light, it makes the perfect accent piece for any living room, entertainment space or media room. -
Transform the atmosphere of your home with just the touch of a button. Use millions of colors to create special moments, set the mood for a party, or simply wind down for the evening. -
Mount the Philips Hue Play smart light bar behind your screen using the included clips and double-sided tape to instantly create beautiful backlighting in the color of your choice. -
Amp your entertainment with smart lighting
Immerse yourself in your movie, game, or music with the magic of light. With millions of colors from which to choose and countless lighting options, you can turn any living room into a private cinema - all you need to bring is the popcorn.
- Philips Hue White and Color Ambiance Play extension - light bar - LED - 16 million colours - white
- Product Type
- Light bar
- Light Source Type
- LED
- Dimmer
- White
- Colour of Illumination
- Luminous Power
- 530 lumens
- Platform
- Hue
- Voltage Required
- AC 110 - 240 V
- Frequency Required
- 50 - 60 Hz
- Product Type
- Light bar
- Dimmer
- Protection class III
Light Source
- LED
- Built-in LED Lamp
- Luminous Power
- 530 lumens
- Lifetime
- 25000 hours
Power Requirements
- Voltage Required
- AC 110 - 240 V
- 50 - 60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Platform
- Hue
- Product Material
- Synthetics
- Body Colour
- White
- IP20
- 4.4 cm
- 25.3 cm
- 3.6 cm
- 280 g
- Shipping Dimensions (WxDxH) / Weight
- 10.2 cm x 29.8 cm x 9.6 cm / 510 g
Philips Hue Play Light Bar Extension Pack - White
