Philips Hue Play Light Bar Extension Pack - White
Quicklinx: GNX2WS00 Mfr#: 915005735501
Type: Light bar
Compatible With: IFTTT, Alexa, Siri, Google Assistant
Hurry, only 2 left in stock!
£49.99 ex VAT
£59.98 inc VAT
Add to your lighting setup with the Phillips Hue Play Light Bar Extension Kit. Because you can connect up to three Hue Play Light Bars together using just one plug, you won't need to find an extra plug socket for this Extension Kit - simply connect it to your current Hue Play (sold separately).
Decorate with ambient smart lights
Transform the atmosphere of your home with just the touch of a button. Use over 16 million colours and 50,000 shades of cool to warm white light to create special moments, set the mood for a party, or simply wind down for the evening.
Amplify your entertainment with smart lighting
Immerse yourself in your movie, game, or music with the magic of light. With millions of colours from which to choose and countless lighting options, you can turn any living room into a private cinema ยท all you need to bring is the popcorn!
Display Hue Play your way
The Philips Hue Play light bar can be mounted to a wall or TV, laid flat on any surface, or stood upright. A versatile smart light, it makes the perfect accent piece for any living room, entertainment space, or media room.
Mount behind your TV
Mount the Philips Hue Play smart light bar behind your screen using the included clips and double-sided tape to instantly create beautiful backlighting in the colour of your choice.
Connect to your Hue Bridge for full smart lighting control
This product requires a connection to the Hue Bridge to unlock the full smart control and features. Control your lights using the Philips Hue app, set timers, routines, add or remove lights and more. *Hue Bridge sold separately
Please note:
Some features require the Philips Hue Bridge (sold separately).
This extension kit doesn't include a mains adapter, it is powered via a Hue Play Light Bar (sold separately).
  • Display Hue Play your way
    The Philips Hue Play light bar can be mounted to a wall or TV, laid flat on any surface or stood upright. A versatile smart light, it makes the perfect accent piece for any living room, entertainment space or media room.
  • Decorate with ambient smart lights
    Transform the atmosphere of your home with just the touch of a button. Use millions of colors to create special moments, set the mood for a party, or simply wind down for the evening.
  • Mount behind your TV
    Mount the Philips Hue Play smart light bar behind your screen using the included clips and double-sided tape to instantly create beautiful backlighting in the color of your choice.
  • Amp your entertainment with smart lighting
    Immerse yourself in your movie, game, or music with the magic of light. With millions of colors from which to choose and countless lighting options, you can turn any living room into a private cinema - all you need to bring is the popcorn.
Philips Hue White and Color Ambiance Play extension - light bar - LED - 16 million colours - white
Light bar
Light Source Type
LED
Dimmer
White
Colour of Illumination
16 million colours
Luminous Power
530 lumens
Platform
Hue
AC 110 - 240 V
Frequency Required
50 - 60 Hz
Light bar
Dimmer
Protection class III
Light Source
LED
Built-in LED Lamp
16 million colours
Luminous Power
530 lumens
Lifetime
25000 hours
Power Requirements
AC 110 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Platform
Hue
Product Material
Synthetics
Body Colour
White
IP20
4.4 cm
25.3 cm
3.6 cm
280 g
10.2 cm x 29.8 cm x 9.6 cm / 510 g
Type: Light bar
Compatible With: Alexa
Compatible With: Siri
Brand: Philips
