Philips Hue Play Gradient Lightstrip for 75" or larger TV
Quicklinx: GQS8WS00 Mfr#: 929002422901
Type: Light strip
Compatible With: Alexa, Google Assistant, Siri, IFTTT
29 In Stock
£174.99 ex VAT
£209.98 inc VAT
Experience the thrill of the cinema at home with the Philips Hue Play Gradient Lightstrip. Get multiple colours of light that react to the content on your screen. Attach to 75" and larger wall-mounted or standing TVs with the included mounts.
Seamlessly Blend Colours
Get a seamless blend of multiple colours of light at the same time in a single LED strip. The colours flow together naturally, casting light against the wall to showcase a unique effect behind your TV.
Surround Lighting Effects
Experience the magic of surround lighting! With 45-degree light projection, the Play Gradient Lightstrip reacts to the content on the entire screen in real time, creating a captivating television viewing and gaming experience. *Requires the Philips Hue Play HDMI sync box and Hue Bridge (sold separately).
Game-changing Home Entertainment
Philips Hue is the only smart lighting brand to easily sync your colour-capable smart lights with films and video games for thrilling home entertainment. The game-changing Hue Sync technology captures the content you're watching or playing and translates it into an immediate light script to create a colourful full-room experience.
Easy Installation
The Philips Hue Play Gradient Lightstrip is specially designed for television entertainment. The LED strip comes in three sizes, fitting TVs of 55" and larger, and includes mounting brackets to make installation quick and easy.
Hue Sync and Hue Bridge Required
The Philips Hue Play gradient Lightstrip requires the Philips Hue Play HDMI sync box, Hue Sync mobile app and a Hue Bridge. The Bridge also allows you to add up to 50 lights and accessories throughout your entire home, create timers and routines, and control your lights from anywhere – inside or outside your home – with the Hue app. The Philips Hue Play HDMI sync box and Hue Bridge are sold separately.
  • Seamlessly blend colors
    Get a seamless blend of multiple colors of light at the same time in a single LED strip. The colors flow together naturally, casting light against the wall to showcase a unique effect behind your TV.
  • Surround lighting effects
    Experience the magic of surround lighting! With 45-degree light projection, the Play gradient lightstrip reacts to the content on the entire screen in real time, creating a captivating television viewing and gaming experience.
  • Game-changing home entertainment
    Philips Hue is the only smart lighting brand to easily sync your color-capable smart lights with films and video games for thrilling home entertainment. The game-changing Hue Sync technology captures the content you're watching or playing and translates it into an immediate light script to create a colorful full-room experience.
  • Easy installation
    The Philips Hue Play gradient lightstrip is specially designed for television entertainment.
Philips Hue Play Gradient - light strip - LED - 20 W - multicolour light - black
Light strip
Light Source Type
LED
Light Cover Type
Diffuser
Wattage
20 W
Colour of Illumination
Multicolour light
Luminous Power
1100 lumens
Beam Angle
45 degree(s)
AC 220 - 240 V
Light strip
Light Cover Type
Diffuser
Double insulated, diffused light effect, 75" TVs compatible, Hue Sync technology
Light Source
LED
Built-in LED Lamp
Wattage
20 W
Multicolour light
Luminous Power
1100 lumens
Beam Angle
45 degree(s)
Lifetime
25000 hours
Power Requirements
AC 220 - 240 V
Product Material
Silicone
Body Colour
Mounting brackets
Package
Box
IP20
Warranty
2 years
1.7 cm
3.04 m
1.6 cm
Length
3.04 m
457 g
29 cm x 29 cm x 14 cm / 1.48 kg
-20 °C
45 °C
Type: Light strip
Compatible With: Siri
Compatible With: IFTTT
Brand: Philips
