Experience the thrill of the cinema at home with the Philips Hue Play Gradient Lightstrip. Get multiple colours of light that react to the content on your screen. Attach to 75" and larger wall-mounted or standing TVs with the included mounts.
Seamlessly Blend Colours
Get a seamless blend of multiple colours of light at the same time in a single LED strip. The colours flow together naturally, casting light against the wall to showcase a unique effect behind your TV.
Surround Lighting Effects
Experience the magic of surround lighting! With 45-degree light projection, the Play Gradient Lightstrip reacts to the content on the entire screen in real time, creating a captivating television viewing and gaming experience. *Requires the Philips Hue Play HDMI sync box and Hue Bridge (sold separately).
Game-changing Home Entertainment
Philips Hue is the only smart lighting brand to easily sync your colour-capable smart lights with films and video games for thrilling home entertainment. The game-changing Hue Sync technology captures the content you're watching or playing and translates it into an immediate light script to create a colourful full-room experience.
Easy Installation
The Philips Hue Play Gradient Lightstrip is specially designed for television entertainment. The LED strip comes in three sizes, fitting TVs of 55" and larger, and includes mounting brackets to make installation quick and easy.
Hue Sync and Hue Bridge Required
The Philips Hue Play gradient Lightstrip requires the Philips Hue Play HDMI sync box, Hue Sync mobile app and a Hue Bridge. The Bridge also allows you to add up to 50 lights and accessories throughout your entire home, create timers and routines, and control your lights from anywhere – inside or outside your home – with the Hue app. The Philips Hue Play HDMI sync box and Hue Bridge are sold separately.
Seamlessly blend colors
Get a seamless blend of multiple colors of light at the same time in a single LED strip. The colors flow together naturally, casting light against the wall to showcase a unique effect behind your TV. -
Surround lighting effects
Experience the magic of surround lighting! With 45-degree light projection, the Play gradient lightstrip reacts to the content on the entire screen in real time, creating a captivating television viewing and gaming experience. -
Game-changing home entertainment
Philips Hue is the only smart lighting brand to easily sync your color-capable smart lights with films and video games for thrilling home entertainment. The game-changing Hue Sync technology captures the content you're watching or playing and translates it into an immediate light script to create a colorful full-room experience. -
Easy installation
The Philips Hue Play gradient lightstrip is specially designed for television entertainment.
- Philips Hue Play Gradient - light strip - LED - 20 W - multicolour light - black
- Product Type
- Light strip
- Light Source Type
- LED
- Light Cover Type
- Diffuser
- Black
- Wattage
- 20 W
- Colour of Illumination
- Multicolour light
- Luminous Power
- 1100 lumens
- Beam Angle
- 45 degree(s)
- Voltage Required
- AC 220 - 240 V
- Product Type
- Light strip
- Light Cover Type
- Diffuser
- Double insulated, diffused light effect, 75" TVs compatible, Hue Sync technology
Light Source
- LED
- Built-in LED Lamp
- Wattage
- 20 W
- Multicolour light
- Luminous Power
- 1100 lumens
- Beam Angle
- 45 degree(s)
- Lifetime
- 25000 hours
Power Requirements
- Voltage Required
- AC 220 - 240 V
- Product Material
- Silicone
- Body Colour
- Black
- Included Accessories
- Mounting brackets
- Package
- Box
- IP20
- Warranty
- 2 years
- 1.7 cm
- 3.04 m
- 1.6 cm
- Length
- 3.04 m
- 457 g
- Shipping Dimensions (WxDxH) / Weight
- 29 cm x 29 cm x 14 cm / 1.48 kg
- -20 °C
- 45 °C
