Play gradient light tube large
Bring the cinema home with the Play gradient light tube large in white. Place or mount beneath a TV to cast a blend of colourful light. Rotate the tube to shine it in any direction – a perfect complement to surround lighting.
Designed for the home cinema
Set it below the TV. Mount it above. Wherever it goes, it creates unique entertainment experiences with a blend of brilliant, colourful light.
Immerse yourself in TV and movies
The Play gradient light tube can react to what's on your screen, making you feel like you're part of the show with its dazzling array of multicolour light.
Escape into the game
Let your character's world spill over the screen into your living room! Whatever console you play on, you can sync every action to the lights around you.
Make music come to life
Sync the Play gradient light tube to your favourite tunes, letting it flash, dim, brighten and change colour along with the beat.
Control your way
Use a Hue app, your voice or smart accessories to control your set-up.
Customise with the Hue app
Control the Play gradient light tube with your smartphone or tablet using one of the Hue apps.
Go hands-free with voice
Pair with smart home assistants, such as Amazon Alexa, Apple HomeKit and Google Assistant, to control your lights with voice commands.
Pair with the Hue sync box
Enable surround lighting with the Philips Hue Play HDMI sync box. Watch your lights – including the Play gradient light tube – flash, dim, brighten and change colour in sync with your screen. Hue Bridge required.
Blend multiple colours of light
The Play gradient light tube shines a seamless blend of colourful light, letting all its different colours flow naturally into one another.
Adjust the angle
Rotate the Play gradient light tube 340 degrees to get the perfect angle of colourful light without any glare on the TV.
- Philips Hue White and Color Ambiance Large Gradient Play - light bar - LED - tube - white
- Product Type
- Light bar - tube
- Light Source Type
- LED
- Light Cover Type
- Diffuser
- Dimmer
- Cable Length
- 2 m
- White
- Luminous Power
- 1800 lumens
- Voltage Required
- AC 100 - 240 V
- Frequency Required
- 50 - 60 Hz
- Product Type
- Light bar
- Shape
- Tube
- Light Cover Type
- Diffuser
- Dimmer
- Cable Length
- 2 m
- Protection class III, replaceable lighting module, Hue Sync technology, 60" TVs compatible
Light Source
- LED
- Built-in LED Lamp
- Luminous Power
- 1800 lumens
- Lifetime
- 25000 hours
Power Requirements
- Voltage Required
- AC 100 - 240 V
- 50 - 60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Required
- Hub Compatibility
- Philips Hue Bridge
- Product Material
- Aluminium
- Body Colour
- White
- Included Accessories
- Power supply
- Package
- Box
- IP20
- Warranty
- 2 years
- 3.1 cm
- 3.4 cm
- Length
- 137.7 cm
- Shipping Dimensions (WxDxH) / Weight
- 12 cm x 141.6 cm x 10 cm / 1.743 kg
