Philips Hue Play Gradient Light Tube Compact - Black
Quicklinx: GVNBWS00 Mfr#: 915005988001
Type: Light bar
Compatible With: Alexa
£141.66 ex VAT
£169.99 inc VAT
Play gradient light tube compact
Bring the cinema home with the Play gradient light tube large in white. Place or mount beneath a TV to cast a blend of colourful light. Rotate the tube to shine it in any direction – a perfect complement to surround lighting.
Designed for the home cinema
Set it below the TV. Mount it above. Wherever it goes, it creates unique entertainment experiences with a blend of brilliant, colourful light.
Immerse yourself in TV and movies
The Play gradient light tube can react to what's on your screen, making you feel like you're part of the show with its dazzling array of multicolour light.
Escape into the game
Let your character's world spill over the screen into your living room! Whatever console you play on, you can sync every action to the lights around you.
Make music come to life
Sync the Play gradient light tube to your favourite tunes, letting it flash, dim, brighten and change colour along with the beat.
Control your way
Use a Hue app, your voice or smart accessories to control your set-up.
Customise with the Hue app
Control the Play gradient light tube with your smartphone or tablet using one of the Hue apps.
Go hands-free with voice
Pair with smart home assistants, such as Amazon Alexa, Apple HomeKit and Google Assistant, to control your lights with voice commands.
Pair with the Hue sync box
Enable surround lighting with the Philips Hue Play HDMI sync box. Watch your lights – including the Play gradient light tube – flash, dim, brighten and change colour in sync with your screen. Hue Bridge required.
Blend multiple colours of light
The Play gradient light tube shines a seamless blend of colourful light, letting all its different colours flow naturally into one another.
Adjust the angle
Rotate the Play gradient light tube 340 degrees to get the perfect angle of colourful light without any glare on the TV.
Philips Hue White and Color Ambiance Compact Gradient Play - light bar - LED - tube - black
Light bar - tube
Light Source Type
LED
Light Cover Type
Diffuser
Dimmer
Cable Length
2 m
Luminous Power
1540 lumens
AC 100 - 240 V
Frequency Required
50 - 60 Hz
Light bar
Shape
Tube
Light Cover Type
Diffuser
Dimmer
Cable Length
2 m
Protection class III, replaceable lighting module, Hue Sync technology, 40" - 55" TVs compatible
Light Source
LED
Built-in LED Lamp
Luminous Power
1540 lumens
Lifetime
25000 hours
Power Requirements
AC 100 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub
Required
Hub Compatibility
Philips Hue Bridge
Product Material
Aluminium
Body Colour
Power supply
Package
Box
IP20
Warranty
2 years / 30 days return
3.1 cm
3.4 cm
Length
87.7 cm
12 cm x 90.1 cm x 10 cm / 1.25 kg
Type: Light bar
Brand: Philips
