Philips Hue Motion Sensor EU
Quicklinx: HWZGWS00 Mfr#: 929003067501
Type: Motion sensor
Compatible With: Google Assistant, Alexa
£29.66 ex VAT
£35.59 inc VAT
Trigger your smart lights with movement. The battery-powered Hue motion sensor can be easily installed anywhere in your home.
  • Trigger smart lights with motion sensors
    Add a Philips Hue motion sensor to your smart lighting system to automatically switch your lights on when movement is detected, helping you navigate safely through your home.
  • Daylight sensor detects light
    The Hue Motion sensor's integrated daylight sensor detects when there is still enough daylight so that lights do not turn on until you need them. If it's still too dark, adjust the light sensitivity of the sensor in the Philips Hue app to personalize when you'd like the motion sensor to activate.
  • Mount the motion sensor anywhere
    The motion sensor for Philips Hue smart lights is battery powered and completely wireless, allowing you to install anywhere inside your home. Place it on a shelf, mount it on a wall or ceiling with a single screw, or place it on any magnetic surface with the included magnet.
  • Customize motion sensor lights
    With the Hue motion sensor, you can customize the lights that come on and their intensity depending on the time of day. During the evening, set the motion sensor to trigger gentle night lights to guide you in the dark. During the day, trigger crisp white light to flood your halls.
Philips Hue - motion sensor - white
Motion sensor
Power Source
Internet of Things (IoT) Platform
Apple HomeKit, Hue
Intelligent Assistant
Alexa, Google Assistant
Wireless
Supported Host Device OS
iOS, Android
White
5.5 cm x 3 cm x 5.5 cm
Motion sensor
Power Source
Wireless
iOS, Android
Hub Compatibility
Philips Hue Bridge
Platform
Apple HomeKit, Hue
AAA type
Required Qty
2
Product Material
Plastic
White
Warranty
IP42
5.5 cm
3 cm
5.5 cm
78 g
Shipping Width
5.5 cm
Shipping Depth
7.2 cm
Shipping Height
17.4 cm
Shipping Weight
130 g
Type: Motion sensor
Compatible With: Alexa
Brand: Philips
