Philips Hue Lily XL Spot Light  - Black
Quicklinx: GNVYWS00 Mfr#: 915005842601
Type: Spot light
Compatible With: IFTTT, Siri, Alexa, Google Assistant
10 In Stock
£91.66 ex VAT
£109.99 inc VAT
Get the style of the Lily spot with a larger, more powerful light still in a low-voltage fixture. Use the hood to reduce glare.
  • Millions of colors of light
    Use millions of shades of white or colored light to highlight outdoor features, such as trees or fountains, and create a unique atmosphere for any occasion.
  • Powerful light output
    Shine bright, focused light on any object in your garden to give it the attention it deserves.
  • Flexibility at its finest
    Lily spotlights adapt to their surroundings, adding a pop of color anywhere in your garden - no matter how your outdoor space is designed.
  • Control your way
    Use a Hue app, your voice or smart accessories to control your outdoor smart lighting set-up.
  • Simple to install
    With the LowVolt technology, you can plug your outdoor lights into the included low-voltage adapter - no complicated wiring required.
  • Versatile mounting options
    Use Lily spot lights however you like: mount high up on a post for downlighting, nestle into the flower bed to highlight a garden or shine light up through the branches of a tree for a unique look.
Philips Hue White and Color Ambiance Lily XL - spot light - LED - 15 W - 16 million colours - 2000-6500 K - black
Spot light
Light Source Type
LED
Supported Light Bulbs Qty
1
Cable Length
0.5 m
Wattage
15 W
Wattage Equivalent
80 W
Energy Efficiency Class
G
Colour of Illumination
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
1050 lumens
Dimmable
Platform
Hue
24 V
Spot light
1
Cable Length
0.5 m
Weatherproof, outdoor usage, protection class III, dustproof, app-controlled
Light Source
LED
Built-in LED Lamp
Wattage
15 W
Wattage Equivalent
80 W
G
Energy Consumption per 1000h
15 kWh
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
1050 lumens
Dimmable
Lifetime
25000 hours
Power Requirements
24 V
Internet of Things (IoT)
Hub
Required
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Product Material
Metal
Body Colour
Package
Box
IP65
Warranty
2 years
112 mm
112 mm
190 mm
1.4 kg
275 mm x 150 mm x 275 mm / 1.72 kg
Type: Spot light
Compatible With: Siri
Compatible With: Alexa
Brand: Philips
