Turn your garden into your own little oasis with these Philips outdoor spotlights. You can turn them on or off from your phone and as the sun’s going down, you can even turn the brightness up as well. Since there’re 16 million shades to choose between, go bold for that dinner party or enjoy a warm glow when you’re getting stuck into a good book. Fancy lights at the front of the house instead? The timer lets you schedule them to turn on automatically for when you arrive home. With a 25,000-hour lifespan, you can keep on enjoying that warm welcome for a long time to come.
Please note, to use the Philips Hue light bulb you’ll need a Philips Bridge (included). You’ll also need to download the free Philips Hue app, which is compatible with all iOS and Android devices.
- Smart spotlight can be wirelessly controlled
- White and coloured bulb – choose from 16 million shades
- Standalone light with a 25,000 hour lifespan
- Schedule a timer to turn lights on automatically
- Dim the brightness to match your mood
                Beautiful spotlightsEnhance your outdoor space and create the right atmosphere for any occasion with Lily spotlights.
                Millions of colors of lightUse millions of shades of white or colored light to highlight outdoor features, such as trees or fountains, and create a unique atmosphere for any occasion.
                Powerful light outputShine bright, focused light on any object in your garden to give it the attention it deserves.
                Flexibility at its finestLily spotlights adapt to their surroundings, adding a pop of color anywhere in your garden - no matter how your outdoor space is designed.
                Simple to installWith the LowVolt technology, you can plug your outdoor lights into the included low-voltage adapter - no complicated wiring required.
                Versatile mounting optionsUse Lily spotlights however you like - mount high up on a post for downlighting, nestle into the flower bed to highlight a garden or shine light up through the branches of a tree for a unique look.
                Easy to extendAdd more Lily spotlights to your set-up with an easy-to-use T-connector, one of the features of the LowVolt system.
- Philips Hue White and Color Ambiance Lily - spot light - LED - 8 W - 16 million colours - 2000-6500 K - black (pack of 3)
- Product Type
- Spot light
- Recommended For
- Garden, patio
- Light Source Type
- LED
- Packaged Quantity
- 3 (specifications are for single item)
- Dimmer
- Black
- Wattage
- 8 W
- Energy Efficiency Class
- G
- Colour of Illumination
- Colour Temperature
- 2000-6500 K
- Luminous Power
- 1770 lumens
- Platform
- Hue
- Voltage Required
- AC 220 - 240 V
- Frequency Required
- 50 - 60 Hz
- Packaged Quantity
- Product Type
- Spot light
- Recommended For
- Garden, patio
- Dimmer
- Double insulated, extendable, LowVolt, preset modes
Light Source
- LED
- Built-in LED Lamp
- Wattage
- 8 W
- G
- Energy Consumption per 1000h
- 0.5 kWh
- 2000-6500 K
- Colour Rendering Index
- 80
- Luminous Power
- 1770 lumens
- Lifetime
- 25000 hours
- Light scheduling
Power Requirements
- Voltage Required
- AC 220 - 240 V
- 50 - 60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub
- Included
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Hue
- Product Material
- Aluminium
- Body Colour
- Black
- Included Accessories
- Network cable
- IP65
- Warranty
- 2 years
- 7 cm
- 8.4 cm
- 19.4 cm
- 3.18 kg
