Philips Hue Lily Extension Spot light - Black
Quicklinx: GNVXWS00 Mfr#: 915005629801
Extend your evenings with Philips Hue outdoor lighting. Set the right ambiance on your patio, balcony or porch and relax. From the warm white light of a summer sun, to the ice cool daylight of winter: you can enjoy any shade of white light to fit your mood throughout the year.
  • Weather-proof design
    This Philips Hue outdoor fixture is specially designed for use in outdoor environments and has undergone rigorous tests to ensure its performance.
  • Set timers for your convenience
    Enjoy longer evenings outside, finish gardening or just put the rubbish outside after sunset. Have your Philips Hue lights turn on automatically by setting schedules or use the sunset/sunrise routine.
  • High-quality aluminum and superior synthetics
    The products are made specifically for outdoor use. Quality materials are used to ensure better performance in the outdoor conditions as well as smart use of materials to optimize radio frequency.
Philips Hue White and Color Ambiance Lily - spot light - LED - 8 W - 16 million colours - 2200-6500 K - black, matte chrome
Spot light
Light Source Type
LED
Dimmer
Cable Length
0.5 m
Black, matte chrome
Wattage
8 W
Wattage Equivalent
49 W
Energy Efficiency Class
G
Colour of Illumination
16 million colours
Colour Temperature
2200-6500 K
Luminous Power
640 lumens
Intelligent Assistant
Google Assistant, Alexa
Platform
Apple HomeKit, Hue
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Spot light
Dimmer
Cable Length
0.5 m
Waterproof
Double insulated, outdoor usage, remote controlled, adjustable lighting time, auto power on/off, dustproof, day/night adjustable sensor
Light Source
LED
Built-in LED Lamp
Wattage
8 W
Wattage Equivalent
49 W
G
Energy Consumption per 1000h
8 kWh
16 million colours
Colour Temperature
2200-6500 K
Luminous Power
640 lumens
Lifetime
25000 hours
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Apple HomeKit, Hue
Product Material
Aluminium
Body Colour
Black, matte chrome
RoHS, REACH, IP65
Warranty
2 years
7 cm
8.4 cm
19.4 cm
430 g
235 mm x 155 mm x 130 mm / 1.06 kg
