Philips Hue Lily and XL Base Kit
Quicklinx: GSPXWS00 Mfr#: 919213000348
Enhance your outdoor space and create the right atmosphere for any occasion with Lily spot lights.
  • Weather-proof design
    This Philips Hue outdoor fixture is specially designed for use in outdoor environments and has undergone rigorous tests to ensure its performance.
  • Set timers for your convenience
    Enjoy longer evenings outside, finish gardening or just put the rubbish outside after sunset. Have your Philips Hue lights turn on automatically by setting schedules or use the sunset/sunrise routine.
  • High-quality aluminum and superior synthetics
    The products are made specifically for outdoor use. Quality materials are used to ensure better performance in the outdoor conditions as well as smart use of materials to optimize radio frequency.
Philips Hue White and Color Ambiance Lily - garden spot light set - LED x 3 - 16 million colours - 2000-6500 K - black
Garden spot light set
Recommended For
Garden, patio
Light Source Type
3 x LED
Dimmer
Cable Length
50 cm
Energy Efficiency Class
G
Colour of Illumination
16 million colours
Colour Temperature
2000-6500 K
Intelligent Assistant
Siri, Google Assistant, Alexa
Platform
Apple HomeKit, Hue
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Recommended For
Garden, patio
Dimmer
Cable Length
50 cm
Waterproof
Weatherproof, outdoor usage, protection class III, dustproof, app-controlled, voice control, LowVolt system
Light Source
3 x LED
Built-in LED Lamp
G
16 million colours
Colour Temperature
2000-6500 K
Colour Rendering Index
80
Lifetime
25000 hours
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Apple HomeKit, Hue
Compatible Application
Philips Hue App
Product Material
Aluminium, synthetics
Body Colour
Mounting kit, power supply
IP65
Warranty
2 years
Dimensions & Weight Details
Spotlight - width: 7 cm x depth: 8.4 cm x height: 19.4 cm - 430 g , Spotlight - width: 11.2 cm x depth: 11.2 cm x height: 19 cm - 1.4 kg
