Philips Hue Lily 40w Base Unit and Ext
Quicklinx: GSPWWS00 Mfr#: 919313000005
Type: Spot light
Compatible With: Google Assistant, Apple HomeKit, Alexa
£274.99 ex VAT
£329.98 inc VAT
Highlight your garden’s best features to create the outdoor space of your dreams with these Philips Lily outdoor spotlights. This bundle includes everything you need to get going – a base kit consisting of three lights, cables, and required power supply, and an extension with an additional light, for a total of four spotlights. Using the Philips Hue app, you can choose from over 16 million colours and even set a timer – no more worrying you forgot to turn them off once you’re tucked up in bed. Plus, you can dim them for a more do-not-disturb ambiance or turn up the brightness when you have guests. What’s more, they’ll keep going for up to 25,000 hours, so they won’t need to be replaced anytime soon.
Please note, to use these Philips Hue spotlights you’ll need to connect it to the Hue Bridge (sold separately), and you’ll also need to download the free Philips Hue app, which is compatible with both Apple and Android devices.
  • Smart light bulb – control from your phone or tablet
  • White and coloured bulb – choose from 16 million shades
  • Standalone light with a 25,000 hour lifespan
  • Schedule a timer to turn lights on automatically
  • Dim the brightness to match your mood
  • Weather-proof design
    This Philips Hue outdoor fixture is specially designed for use in outdoor environments and has undergone rigorous tests to ensure its performance.
  • Set timers for your convenience
    Enjoy longer evenings outside, finish gardening or just put the rubbish outside after sunset. Have your Philips Hue lights turn on automatically by setting schedules or use the sunset/sunrise routine.
  • High-quality aluminum and superior synthetics
    The products are made specifically for outdoor use. Quality materials are used to ensure better performance in the outdoor conditions as well as smart use of materials to optimize radio frequency.
Philips Hue White and Color Ambiance Lily - spot light - LED - 8 W - 16 million colours - 2000-6500 K - black (pack of 4)
Spot light
Recommended For
Garden, patio
Light Source Type
LED
Packaged Quantity
4 (specifications are for single item)
Dimmer
Wattage
8 W
Energy Efficiency Class
G
Colour of Illumination
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
1770 lumens
Intelligent Assistant
Alexa, Apple HomeKit, Google Assistant - indirect
Platform
Hue
Communications Technology
Zigbee
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Packaged Quantity
Spot light
Recommended For
Garden, patio
Dimmer
LowVolt, extendable, preset modes
Light Source
LED
Built-in LED Lamp
Wattage
8 W
G
16 million colours
Colour Temperature
2000-6500 K
Colour Rendering Index
80
Luminous Power
1770 lumens
Lifetime
25000 hours
Light scheduling
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Zigbee
Voice Controlled
Indirect
Product Material
Aluminium
Body Colour
IP65
Warranty
2 years
7 cm
8.4 cm
19.4 cm
3.18 kg
Type: Spot light
Compatible With: Apple HomeKit
Compatible With: Alexa
Brand: Philips
