Highlight your garden’s best features to create the outdoor space of your dreams with these Philips Lily outdoor spotlights. This bundle includes everything you need to get going – a base kit consisting of three lights, cables, and required power supply, and an extension with an additional light, for a total of four spotlights. Using the Philips Hue app, you can choose from over 16 million colours and even set a timer – no more worrying you forgot to turn them off once you’re tucked up in bed. Plus, you can dim them for a more do-not-disturb ambiance or turn up the brightness when you have guests. What’s more, they’ll keep going for up to 25,000 hours, so they won’t need to be replaced anytime soon.
Please note, to use these Philips Hue spotlights you’ll need to connect it to the Hue Bridge (sold separately), and you’ll also need to download the free Philips Hue app, which is compatible with both Apple and Android devices.
- Smart light bulb – control from your phone or tablet
- White and coloured bulb – choose from 16 million shades
- Standalone light with a 25,000 hour lifespan
- Schedule a timer to turn lights on automatically
- Dim the brightness to match your mood
Weather-proof design
This Philips Hue outdoor fixture is specially designed for use in outdoor environments and has undergone rigorous tests to ensure its performance. -
Set timers for your convenience
Enjoy longer evenings outside, finish gardening or just put the rubbish outside after sunset. Have your Philips Hue lights turn on automatically by setting schedules or use the sunset/sunrise routine. -
High-quality aluminum and superior synthetics
The products are made specifically for outdoor use. Quality materials are used to ensure better performance in the outdoor conditions as well as smart use of materials to optimize radio frequency.
- Philips Hue White and Color Ambiance Lily - spot light - LED - 8 W - 16 million colours - 2000-6500 K - black (pack of 4)
- Product Type
- Spot light
- Recommended For
- Garden, patio
- Light Source Type
- LED
- Packaged Quantity
- 4 (specifications are for single item)
- Dimmer
- Black
- Wattage
- 8 W
- Energy Efficiency Class
- G
- Colour of Illumination
- Colour Temperature
- 2000-6500 K
- Luminous Power
- 1770 lumens
- Intelligent Assistant
- Alexa, Apple HomeKit, Google Assistant - indirect
- Platform
- Hue
- Communications Technology
- Zigbee
- Voltage Required
- AC 220 - 240 V
- Frequency Required
- 50 - 60 Hz
- Packaged Quantity
- Product Type
- Spot light
- Recommended For
- Garden, patio
- Dimmer
- LowVolt, extendable, preset modes
Light Source
- LED
- Built-in LED Lamp
- Wattage
- 8 W
- G
- 2000-6500 K
- Colour Rendering Index
- 80
- Luminous Power
- 1770 lumens
- Lifetime
- 25000 hours
- Light scheduling
Power Requirements
- Voltage Required
- AC 220 - 240 V
- 50 - 60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Hue
- Zigbee
- Voice Controlled
- Indirect
- Product Material
- Aluminium
- Body Colour
- Black
- IP65
- Warranty
- 2 years
- 7 cm
- 8.4 cm
- 19.4 cm
- 3.18 kg
