Philips Hue Lightstrip Plus V4 2m base with Bridge Starter Kit
Quicklinx: H50PWS00 Mfr#: 919313000067
Type: Light strip
10 In Stock
£83.33 ex VAT
£99.99 inc VAT
From elevating the kitchen worktops to making the kid’s room more magical, this Philips smart LED strip will transform any space. There’re 16 million shades to choose from, so you can enjoy a warm white while you’re cooking or brighten up bedtime stories with deep hues of blue, pink and purple. It’s controlled from the app on your phone, letting you switch colours in seconds, and when the little ones need help settling down, the light can be dimmed as well. Busy day tomorrow? Give the family a hand waking up with the timer that turns the light on automatically. And thanks to the 25,000-hour lifespan, you won’t have to think about replacing the strip any time soon either.
Please note, to use the Philips Hue light bulb you’ll need a Philips Bridge (included). You’ll also need to download the free Philips Hue app, which is compatible with all iOS and Android devices.
  • Smart lightstrip can be wirelessly controlled
  • White and coloured bulb – choose from 16 million shades
  • Standalone light with a 25,000 hour lifespan
  • Schedule a timer to turn lights on automatically
  • Dim the brightness to match your mood
  • Optimal design, optimal effect
    The transparent sleeve was designed to keep dust and damage away from your lightstrip, meaning the light output is always at the optimal level.
  • Bright, powerful light
    Get consistent color - and with millions of them, it's really any color - and bright, beautiful light.
  • Get the perfect atmosphere
    From fancy get-togethers to family game nights, whatever occasion can be dressed up with the right colorful light.
  • Shape light the way you like
    Bend it. Curve it. Cut it to size. Create your personal lighting vibes.
Philips Hue V4 - light strip - LED - 20 W - multicolour/warm to cool white light - 2000-6500 K
Light strip
Light Source Type
LED
Dimmer
Usage Modes
Energize, concentrate, read, relax
Wattage
20 W
Colour of Illumination
Multicolour/warm to cool white light
Colour Temperature
2000-6500 K
Luminous Power
1700 lumens
Intelligent Assistant
Google Assistant - indirect
Communications Technology
Bluetooth
Light strip
Dimmer
Usage Modes
Cuttable
Light Source
LED
Built-in LED Lamp
Wattage
20 W
Colour Temperature
2000-6500 K
Luminous Power
1700 lumens
Internet of Things (IoT)
Compatible Application
Philips Hue App
Bluetooth
Google Assistant
Voice Controlled
Indirect
Hue bridge
Package
Box
IP20
Warranty
2 years
14.5 mm
5.5 mm
Length
2 m
337 g
Type: Light strip
Brand: Philips
