Philips Hue Lightstrip Plus V4 2m Base
Quicklinx: FVSMWS00 Mfr#: 929002269101
Type: Light strip
Compatible With: Alexa, Google Assistant
Select:
£58.33 ex VAT
£69.99 inc VAT
Express delivery Order within the next 23 hours for delivery on Friday
Colourful. Flexible. Powerful.
Create an immersive experience — along the bar, under cabinets, behind entertainment centers — with the flexibility to bend, cut, and extend Lightstrip Plus however you need.
Bring brilliantly coloured light to any area of your home with the flexible Lightstrip. Unlike other strip lighting options, the Lightstrip can be paired with a Hue Bridge to offer a full suite of smart lighting control and features.
Shape, cut, or extend your Lightstrip
Completely flexible, the indoor strip light lets you shape and bend it to fit your space. Attach a Lightstrip extension for larger surfaces or cut the strip to size to fit into a smaller space. The leftover piece won’t go to waste: use the included connector clip to attach the strip you’ve cut off to another Lightstrip base unit!
Extendible up to 10 metres
Extend your Philips Hue Lightstrip Plus by up to 10 metres by adding 1-metre extensions to cover larger surfaces and enable wider applications. From bright cove lighting to ambient navigation light in your hallway or stairs, anything is possible. Philips Hue lightstrip plus gives you full colour consistency from the first to the last extension.
Bright light for both function and mood
With light coverage over its total length and a high output of 1,600 lumen, Philips Hue strip lights provide enough light to be used both as a decorative and functional light source.
Control up to 10 lights with the Bluetooth app
With the Hue Bluetooth app, you can control your Hue smart lights in a single room of your home. Add up to 10 smart lights and control them all with just the touch of a button on your mobile device.
Control lights with your voice
Philips Hue works with Amazon Alexa and the Google Assistant when paired with a compatible Google Nest or Amazon Echo device. Simple voice commands allow you to control multiple lights in a room, or just a single lamp.
Create a personalised experience with colourful smart light
Transform your home with over 16 million colours, instantly creating the right atmosphere for any event. With the touch of a button, you can set a festive mood for a party, turn your living room into a movie theatre, enhance your home decor with colour accents, and much more.
Set the right mood with warm to cool white light
These bulbs and light fixtures offer different shades of warm to cool white light. With complete dimmability from bright to low nightlights, you can tune your lights to the perfect shade and brightness of light for your daily needs.
Unlock full suite of smart light features with Hue Bridge
Add a Hue Bridge (sold separately) to your smart lights to experience the full suite of Philips Hue features. With a Hue Bridge, you can add up to 50 smart lights to control throughout your home. Create routines to automate your entire smart home lighting set-up. Control your lights while away from home or add accessories such as motion sensors and smart switches.
Amp your entertainment with smart lighting
Immerse yourself in your movie, game, or music with the magic of light. With millions of colours from which to choose and countless lighting options, you can turn any living room into a private cinema – all you need to bring is the popcorn!
  • Flexible for every space, every moment
    Place a lightstrip where you like to relax most. Dim it down low, set to warm colors, and make your space comfortable, cozy, and completely your own. From fancy get-togethers to family game nights, whatever occasion can be dressed up with the right colorful light. Lightstrips can be tucked behind cabinets or underneath shelves to give any space an interesting, colorful, and ever-changing design element.
  • Control your way
    Use the Hue app, your voice, or smart accessories to control your setup.
  • Bright, powerful light
    Get consistent color - and with millions of them, it's really any color - and bright, beautiful light.
  • Optimal design, optimal effect
    The transparent sleeve was designed to keep dust and damage away from your lightstrip, meaning the light output is always at the optimal level.
  • Ultimate flexibility
    Cut the lightstrip on the marked lines to fit your space or make it even longer with extension strips. Bend, curve, and shape it to fit your space.
Philips Hue Lightstrip Plus - light strip - LED - 20 W - 16 million colours - 2000-6500 K - multicolour
Light strip
Light Source Type
LED
Multicolour
Wattage
20 W
Colour of Illumination
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
1600 lumens
Dimmable
Intelligent Assistant
Google Assistant, Alexa - indirect
Platform
Hue
Communications Technology
Bluetooth
Light strip
Extendable, ZigBee Light Link, 16 million changeable colours, cuttable
Light Source
LED
Built-in LED Lamp
Wattage
20 W
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
1600 lumens
Starting Time
0 sec
Dimmable
Lifetime
25000 hours
Instant full light
Internet of Things (IoT)
Hub
Required
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Bluetooth
Voice Controlled
Indirect
Product Material
Synthetics
Body Colour
Multicolour
Power adapter, power supply
Package
Box
IP20
Warranty
2 years
Length
2000 mm
358 g
140 mm x 75 mm x 140 mm / 445 g
-20 °C
45 °C
Type: Light strip
Brand: Philips
