Philips Hue Lightstrip Base and Extension V4 Bundle
Quicklinx: FVSPWS00 Mfr#: 919213000347
Type: Light strip
Compatible With: Google Assistant, Alexa, Siri, IFTTT
14 left in stock
£56.66 ex VAT
£67.99 inc VAT
Express delivery Order within the next 6 hours for delivery tomorrow
2m Lightstrip and 1m Smart LED Extension Kit with Bluetooth
Mount behind your TV or PC monitor to paint your walls with light
Choose from 16 million colours
Work straight out the box
Philips Hue Lightstrip - light strip kit - LED - 20 W - multicolour/warm to cool white light - 2000-6500 K - multicolour
Light strip kit
Light Source Type
LED
Dimmer
Multicolour
Wattage
20 W
Colour of Illumination
Multicolour/warm to cool white light
Colour Temperature
2000-6500 K
Communications Technology
Bluetooth
Light strip kit
Dimmer
Light Source
LED
Wattage
20 W
Colour Temperature
2000-6500 K
Lifetime
10 years
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Bluetooth
Product Material
Silicone
Body Colour
Multicolour
Power supply
IP20
Warranty
2 years
1.45 cm
5.5 mm
Length
2 m
Dimensions & Weight Details
Extension - width: 1.45 cm x depth: 1 m x height: 5.5 mm
20 cm x 30 cm x 10 cm / 1.33 kg
Type: Light strip
Compatible With: Alexa
Compatible With: Siri
Compatible With: IFTTT
Brand: Philips
Stock Status: While stocks last
Stock Status: Clearance
