Make a statement in any room with the contemporary design of the medium Infuse ceiling light in white. Cast a subtle glow against the ceiling while shining powerful light downwards - in any shade of white or colored light.
Control up to 10 lights with the Bluetooth app
With the Hue Bluetooth app, you can control your Hue smart lights in a single room of your home. Add up to 10 smart lights and control them all with just the touch of a button on your mobile device. -
Set up hands-free voice control
Philips Hue works with Amazon Alexa and Google Assistant when paired with a compatible Google Nest or Amazon Echo device. Control multiple lights in a room or just a single lamp with simple voice commands. -
Create a personalized experience with colorful smart light
Use millions of colors of light to transform any room in your home, instantly creating a unique atmosphere. With the touch of a button, you can transform your living room with a pink glow or light your entire home in vibrant colors to turn any night at home into a personalized party. -
Optimized light recipes for your daily activities
Use the preset Philips Hue light recipes to fit your mood or activities throughout the day. Start your day with the bright white light of the Energize light recipe, or unwind with the subtle, soft light of Relax. Reading a book in the bath? Set the Read recipe for just the right light.
- Philips Hue White and Color Ambiance Infuse M - ceiling lamp - LED - 33.5 W - 2000-6500 K - white
- Product Type
- Ceiling lamp
- Recommended For
- Living room, bedroom
- Light Source Type
- LED
- Style
- Modern
- Light Cover Type
- Diffuser
- Dimmer
- White
- Wattage
- 33.5 W
- Colour Temperature
- 2000-6500 K
- Luminous Power
- 2350 lumens
- Intelligent Assistant
- Google Assistant, Alexa - indirect
- Platform
- Nest, Echo
- Communications Technology
- Bluetooth
- Frequency Required
- 50 - 60 Hz
- Product Type
- Ceiling lamp
- Recommended For
- Style
- Modern
- Light Cover Type
- Diffuser
- Dimmer
- Protection class I, remote controlled, app-controlled
Light Source
- LED
- Built-in LED Lamp
- Wattage
- 33.5 W
- 2000-6500 K
- Luminous Power
- 2350 lumens
- Lifetime
- 25000 hours
Power Requirements
- 50 - 60 Hz
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Hub Compatibility
- Philips Hue Bridge
- Platform
- Nest, Echo
- Compatible Application
- Philips Hue App
- Bluetooth
- Voice Controlled
- Indirect
- Product Material
- Metal, synthetics
- Body Colour
- White
- IP20
- Warranty
- 2 years / 30 days return
- 8.4 cm
- Diameter
- 38.1 cm
- 3.138 kg
- Shipping Dimensions (WxDxH) / Weight
- 43.7 cm x 45.7 cm x 10 cm / 3.938 kg
