Philips Hue Infuse Medium Ceiling Lamp - Black
Quicklinx: GVN6WS00 Mfr#: 915005997301
The contemporary design of the medium Infuse ceiling light in black makes a statement, casting subtle light against the ceiling and a powerful glow below. Set the mood with colorful light or relax in warm tones.
  • Control up to 10 lights with the Bluetooth app
    With the Hue Bluetooth app, you can control your Hue smart lights in a single room of your home. Add up to 10 smart lights and control them all with just the touch of a button on your mobile device.
  • Set up hands-free voice control
    Philips Hue works with Amazon Alexa and Google Assistant when paired with a compatible Google Nest or Amazon Echo device. Control multiple lights in a room or just a single lamp with simple voice commands.
  • Create a personalized experience with colorful smart light
    Use millions of colors of light to transform any room in your home, instantly creating a unique atmosphere. With the touch of a button, you can transform your living room with a pink glow or light your entire home in vibrant colors to turn any night at home into a personalized party.
  • Optimized light recipes for your daily activities
    Use the preset Philips Hue light recipes to fit your mood or activities throughout the day. Start your day with the bright white light of the Energize light recipe, or unwind with the subtle, soft light of Relax. Reading a book in the bath? Set the Read recipe for just the right light.
Philips Hue White and Color Ambiance Infuse M - ceiling lamp - LED - 33.5 W - 2000-6500 K - black
Ceiling lamp
Recommended For
Living room, bedroom
Light Source Type
LED
Style
Modern
Light Cover Type
Diffuser
Dimmer
Wattage
33.5 W
Energy Efficiency Class
G
Colour Temperature
2000-6500 K
Luminous Power
2100 - 2350 lumens
Intelligent Assistant
Google Assistant, Alexa - indirect
Platform
Nest, Echo
Communications Technology
Bluetooth
AC 24 V
Frequency Required
50 - 60 Hz
Ceiling lamp
Recommended For
Style
Modern
Light Cover Type
Diffuser
Dimmer
Protection class I, remote controlled, app-controlled
Light Source
LED
Built-in LED Lamp
Wattage
33.5 W
G
Colour Temperature
2000-6500 K
Luminous Power
2100 - 2350 lumens
Lifetime
25000 hours
Power Requirements
AC 24 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Nest, Echo
Compatible Application
Philips Hue App
Bluetooth
Voice Controlled
Indirect
Product Material
Metal, synthetics
Body Colour
Package
Box
IP20
Warranty
2 years / 60 days return
8.4 cm
Diameter
38.1 cm
3.138 kg
43.7 cm x 45.7 cm x 10 cm / 3.938 kg
