Philips Hue Impress Wall Lantern - Mains Powered
Quicklinx: GNXHWS00 Mfr#: 915005730601
Type: Outdoor lighting
Compatible With: Siri, Google Assistant, Alexa, IFTTT
£87.49 ex VAT
£104.98 inc VAT
Now expand Hue to your outdoors. The Impress wall light can be connected to your existing Hue bridge to enjoy all the features like away from home control and scheduling but is also great at creating ambience. Philips Hue bridge not included.
  • Special light for special occasions
    Holiday cheer starts here - with smart light! Use your Philips Hue lights to transform your home into a festive experience: bright reds and greens for Christmas, subtle pastels for spring or even an eerie purple glow to create the most haunted house on the street at Halloween.
  • Unwind with warm to cool white light
    Extend your evenings with Philips Hue outdoor lighting. Set the right ambience on your patio, balcony or porch and relax. From the warm white light of a summer sun, to the ice cool daylight of winter: you can enjoy any shade of white light to fit your mood throughout the year.
  • Control it your way
    Connect your Philips Hue lights with the Bridge and start discovering the endless possibilities. Control your lights from your smartphone or tablet via the Philips Hue app, or add the indoor switches to your system to change your lights. Set timers, notifications, alarms and more for the full Philips Hue experience. Philips Hue even works with Amazon Alexa, Apple Homekit and the Google Assistant to allow you to control your lights with your voice.
  • Paint your outdoors with 16 million colors
    With Philips Hue outdoor lighting, there's no limit to the magic you can add. Play with 16 million colors and all shades of white light to create the effect you want. Highlight objects, trees or pathways to make your space stand out. Use the Hue app to save your favorite light settings and recall them whenever you want with the tap of a finger.
  • Requires a Philips Hue bridge
    Connect your Philips Hue lights with the Bridge to control your lights from your smart phone or tablet via the Philips Hue app. Or control your Philips Hue lights with the Philips Hue dimmer indoor switch for on/off and dimming functionalities.
  • Set timers for your convenience
    Enjoy longer evenings outside, finish gardening or just put the rubbish outside after sunset. Have your Philips Hue lights turn on automatically by setting schedules or use the sunset/sunrise routine. And of course, you can also turn off or dim your lights this way. You'll never have to worry whether you've left any lights on.
  • Weather-proof (IP44)
    This Philips Hue outdoor fixture is specially designed for use in outdoor environments and has undergone rigorous tests to ensure its performance. The IP level is described by two figures: the first one refers to the protection level against dust, the second against water. This lamp is designed with IP44: it is protected against water splashed from any direction. This product is ideal for general outdoor use.
  • High light output
    This Philips Hue light provides you with enough output to light up your garden comfortably. Use this Philips Hue light to help you light up your entrances, create more ambience and bring your outdoors to the next level by setting the scene for your moment.
  • Set your lights to welcome you home
    Experience the comfort of your lights turning on automatically when you arrive and turning off when you leave. Unload your car, enter your house, all with the comfort of the right light. Either use the Philips Hue outdoor sensor, or set the Hue app to Home or Away mode to switch on all your lights, or let geolocation do it for you, all without touching a button. It's as easy as that.
  • Smart control, home and away
    Light up your outdoors and see what's going on outside. By connecting your outdoor lights with the Hue Bridge you can control them in any way you like. With the Philips Hue outdoor sensor, our indoor remote control options, such as the Philips Hue app or using your voice (Amazon Alexa, Apple HomeKit or Google Assistant), you can control your outdoor lights. You can set light schedules to mimic your presence. Control your outdoor lighting from the comfort of your home or from any other location.
Philips Hue Impress - wall lamp - LED light bulb - 8 W - 16 million colours - black
Wall lamp
Light Source Type
LED light bulb
Supported Light Bulbs Qty
1
Dimmer
Wattage
8 W
Energy Efficiency Class
A
Colour of Illumination
16 million colours
Luminous Power
1200 lumens
Intelligent Assistant
Alexa - indirect
Platform
Hue
Communications Technology
Zigbee
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Wall lamp
1
Supported Light Bulb Wattage
8 W
Compatible Light Bulb Energy Class
A, B, C, D, E, A+
Dimmer
Outdoor usage
Light Source
LED light bulb
Wattage
8 W
A
16 million colours
Luminous Power
1200 lumens
Lifetime
25000 hours
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Communications Type
Product-to-product
Zigbee
Alexa
Voice Controlled
Indirect
Product Material
Metal, glass
Body Colour
IP44
Warranty
2 years
11.7 cm
24 cm
Length
19 cm
1.825 kg
16.6 cm x 23.6 cm x 29.5 cm / 2.07 kg
Compatible With: Alexa
Compatible With: IFTTT
Brand: Philips
