Philips Hue Impress Slim Outdoor Wall Light Twin Pack
Quicklinx: GQSNWS00 Mfr#: 919213000343
Type: Outdoor lighting
Compatible With: IFTTT, Siri, Alexa, Google Assistant
Hurry, only 2 left in stock!
£216.65 ex VAT
£259.98 inc VAT
Smart light bulb – control from your phone or tablet
White and coloured bulb – choose from 16 million shades
Standalone light with a 25,000 hour lifespan
Schedule a timer to turn lights on automatically
Dim the brightness to match your mood
  • 16 million colors
    Create your perfect ambience with over 16 million colors.
  • Unwind with warm to cool white light
    Extend your evenings with Philips Hue outdoor lighting. Set the right ambience on your patio, balcony or porch and relax. From the warm white light of a summer sun to the ice cool daylight of winter - you can enjoy any shade of white light to fit your mood throughout the year.
  • High-quality aluminum and tempered glass
    The products are specifically made for outdoor use, using high-quality aluminum and tempered glass to ensure excellent performance in outdoor conditions. Additionally, smart use of materials is employed to optimize radio frequency.
  • Weather-proof design
    This Philips Hue outdoor fixture is specially designed for use in outdoor environments and has undergone rigorous tests to ensure its performance.
  • Easy to install and extend
    Brighten up dark paths, create highlights in your landscaping or create a unique ambience on the patio.
Philips Hue Impress Slim - wall lamp - LED - 8 W - 16 million colours/warm to cool white light - 2000-6500 K - black (pack of 2)
Wall lamp
Light Source Type
LED
Packaged Quantity
2 (specifications are for single item)
Dimmer
Wattage
8 W
Colour of Illumination
Colour Temperature
2000-6500 K
Luminous Power
710 - 1180 lumens
Platform
Hue
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Packaged Quantity
Wall lamp
Dimmer
Weatherproof, outdoor usage, LowVolt system
Light Source
LED
Built-in LED Lamp
Wattage
8 W
Colour Temperature
2000-6500 K
Colour Rendering Index
80
Luminous Power
710 - 1180 lumens
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Product Material
Glass
Body Colour
IP44
Warranty
2 years
12 cm
14.1 cm
24 cm
14.9 cm x 19.4 cm x 33.6 cm / 2 kg
Compatible With: Siri
Compatible With: Alexa
Brand: Philips
