Philips Hue Impress Pedestal - Black 2x8W
Quicklinx: GVRJWS00 Mfr#: 915005731001
Expand Hue to your outdoors. The Impress pedestal light can be connected to your existing Hue bridge to enjoy all features like away-from-home control and scheduling but is also great at crating ambience.
  • Special occasions
    Family or friends coming over? Set your outdoor lights to match the occasion. Whether it's a cozy dinner on the balcony, a BBQ on the patio or party in the back garden, you can add a touch of magic to every get together with Philips Hue. Create colorful scenes or slow-moving dynamic effects to enjoy these special moments to the full.
  • Warm-to-cool white light
    Extend your evenings with Philips Hue outdoor lighting. Set the right ambience on your patio, balcony or porch and relax. From the warm white light of a summer sun, to the ice cool daylight of winter: you can enjoy any shade of white light to fit your mood throughout the year.
  • Paint your outdoors
    With Philips Hue outdoor lighting, there's no limit to the magic you can add. Play with 16 million colors and all shades of white light to create the effect you want. Highlight objects, trees or pathways to make your space stand out.
  • Weatherproof (IP44)
    This Philips Hue outdoor fixture is specially designed for use in outdoor environments. The IP level is described by two figures: the first one refers to the protection level against dust, the second against water. This lamp is designed with IP44: it is protected against water splashed from any direction. This product is ideal for general outdoor use.
Philips Hue Impress - pedestal light - LED light bulb - 8 W - 16 million colours - black
Pedestal light
Light Source Type
LED light bulb
Supported Light Bulbs Qty
1
Dimmer
Wattage
8 W
Energy Efficiency Class
A
Colour of Illumination
16 million colours
Luminous Power
1200 lumens
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Pedestal light
1
Supported Light Bulb Wattage
8 W
Compatible Light Bulb Energy Class
A, B, C, D, E, A+
Dimmer
Outdoor usage
Light Source
LED light bulb
Wattage
8 W
A
16 million colours
Luminous Power
1200 lumens
Lifetime
25000 hours
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Product Material
Metal, glass
Body Colour
IP44
Warranty
2 years
10 cm
40 cm
Length
10 cm
1.58 kg
15.6 cm x 15.6 cm x 45.6 cm / 1.83 kg
