Philips Hue Gradient Signe Floor Lamp - White
Quicklinx: GSPYWS00 Mfr#: 915005987701
Type: Floor lamp
Compatible With: Alexa, Google Assistant
£233.33 ex VAT
£279.99 inc VAT
Complement your home's decor with the slim, stylish design of the gradient Signe floor lamp, which blends multiple colors together to paint the walls with a unique gradient of light.
  • +10 year lifespan
  • Blends white and coloured light
  • Instant wireless dimming
  • Bluetooth and Hue Bridge compatible
  • Control lights with app or voice
  • Includes power supply
  • Create a unique experience
    Complement your home decor with the slim, stylish design of the gradient Signe floor lamp, which blends multiple colors together to paint the walls with a unique gradient of light.
  • Seamless blend of colors
    Get a seamless blend of multiple colors of light at the same time in a single lamp. The colors flow together naturally, casting light to showcase a unique effect.
  • Set the mood with color
    Transform any room for an immersive entertainment experience, create the perfect atmosphere for a get-together with friends, or complement your home decor. Amp up the ambiance of special moments with the use of dynamic scenes to create the perfect mood in any situation.
Philips Hue White and Colour Ambiance Gradient Signe - floor lamp - LED - 29 W - 2000-6500 K - white
Floor lamp
Recommended For
Living room, bedroom
Light Source Type
LED
Dimmer
Cable Length
2 m
White
Wattage
29 W
Energy Efficiency Class
G
Colour Temperature
2000-6500 K
Luminous Power
2250 lumens
Intelligent Assistant
Google Assistant, Alexa - indirect
Platform
Hue
Communications Technology
Bluetooth, Zigbee
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Floor lamp
Recommended For
Dimmer
Cable Length
2 m
Double insulated, controlled via Bluetooth, app-controlled
Light Source
LED
Built-in LED Lamp
Wattage
29 W
G
Colour Temperature
2000-6500 K
Luminous Power
2250 lumens
Lifetime
25000 hours
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Compatible Application
Philips Hue App
Bluetooth, Zigbee
Voice Controlled
Indirect
Product Material
Aluminium
Body Colour
White
Package
Box
IP20
Warranty
2 years
11.1 cm
11.1 cm
145.8 cm
2.275 kg
3.325 kg
Type: Floor lamp
Brand: Philips
