Philips Hue Gradient Lightstrip Extension
Quicklinx: GW0KWS00 Mfr#: 929002995002
Philips Hue Gradient Lightstrip lets you blend multiple colours of light, and create dynamic, moving effects, with fully flexible design so you can shape and bend it for easy cornering and installation in hard-to-reach places. You can transform your living room, bedroom, kitchen or other rooms and choose from 16 million colours to create an ambiance that suits any mood, and control it via an app.
This kit includes 1 x 1m Lightstrip extension. Please note, it requires a Lightstrip Base Unit in order to work (sold separately).
Colourful, flexible and powerful
With easy setup, you can start adding colour to your home: under kitchen cabinets, kitchen islands, bed frames or behind your TV. You can shape, cut, re-use or extend your Lightstrip to any solid surface using the adhesive tape and get the flexibility you need.
Bluetooth
With the Hue Bluetooth app (available on iOS and Android), you can control this Lightstrip directly from your smart phone, without the need for the Hue bridge. The app can control up to ten lights.
Play with colour
Choose from 16 million colours including warm to cool white light to create an ambiance that suits any mood. Perfect for film nights, parties, bedtime stories, or just relaxing.
Control lights with your voice
Works with Alexa, Google Assistant and Apple HomeKit devices for hands-free voice control. Voice control requires set up with the Hue Bridge (sold separately).
Hue smart lighting requires a separate Hue Bridge to connect to your home network for the full suite of available features (e.g. syncing your lights with music and movies, or controlling them when away from home).
