Philips Hue Gradient Lightstrip Extension - 1 metre
Quicklinx: H1S3WS00 Mfr#: 929002995001
Type: Light strip extension
Compatible With: Alexa, Google Assistant
Hurry, only 1 left in stock!
£38.92 ex VAT
£46.70 inc VAT
Extend the length of your Philips Hue ambiance gradient light strip, covering a larger area with a blend of colorful light.
Create a five-star hotel look at home
Change the look and feel of your space to match the occasion, whether you're lounging in the living room or hosting an intimate dinner party.
Wake up more naturally
Specially made for gradient lights, Wake up automations in the Sunrise style let this lightstrip act as the horizon to a beautiful personal sunrise right in your bedroom.
Get the best light for any moment of the day
Cool blue tones to feel more energised. Warm glows to wind down. No matter what time of the day, your ambiance gradient lightstrip can offer the best light for that moment.
Control your way
Use the Hue app, your voice, or smart accessories to control your setup.
Customise with the Hue app
Set up and customise your ambiance gradient lightstrip right in the Hue app! Change the colour, create a custom gradient, and more.
Add accessories
Use smart accessories such as a dimmer switch or motion sensor to get a little more convenience out of your ambiance gradient lightstrip.
Go hands-free with voice
Pair with smart home assistants such as Amazon Alexa, Apple Home, and Google Assistant, to control your ambiance gradient lightstrip with your voice.
First-class light experience
With gradient technology, excellent colour consistency, and a high light output, your ambiance gradient lightstrip offers only the best light experience.
Premium opaque sleeve
Specially designed for a diffused look, its opaque sleeve ensures a seamless, smooth gradient effect and reduced reflection.
Set the mood with scenes and effects
Handcrafted by lighting designers, the scenes in the Hue scene gallery let you choose exactly how to set the mood in your space. Effects take it one step further, letting your lights mimic a cosy fireplace's flames or candlelit room.
  • Shape the light the way you like
    Bend it. Curve it. Cut it to size. Create your personal lighting vibes.
  • Add colorful accents
    Tucked behind bookshelves and tables, the light strip creates colorful effects that instantly transform your decor.
  • Create a peaceful oasis
    Surround yourself in a wash of warm, glowing light to create a relaxing atmosphere in any room of your home.
  • Be guided by light
    When illuminating hallways and common areas, the light strip helps you make your way through your home safely.
Philips Hue White and Color Ambiance Gradient - light strip extension - LED - 12.3 W - 2000-6500 K - white
Light Source Type
LED
Light Cover Type
Diffuser
Usage Modes
Bright, spring blossom, savannah sunset, smaragd island
White
Wattage
12.3 W
Colour Temperature
2000-6500 K
Luminous Power
1000 lumens
Dimmable
Intelligent Assistant
Google Assistant, Alexa - indirect
Platform
Hue
Communications Technology
Bluetooth, Zigbee
AC 220 - 240 V
Light Cover Type
Diffuser
Usage Modes
Self-adhesive, indoor usage, Android compatible, iOS compatible, flexible, cuttable, app-controlled, extendable (up to 10 m)
Light Source
LED
Built-in LED Lamp
Wattage
12.3 W
Colour Temperature
2000-6500 K
Luminous Power
1000 lumens
Dimmable
Lifetime
25000 hours
Power Requirements
AC 220 - 240 V
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Compatible Application
Philips Hue App
Bluetooth, Zigbee
Voice Controlled
Indirect
Product Material
Silicone
Body Colour
White
IP20
Warranty
2 years
14.5 mm
5.5 mm
80 g
14.6 cm x 14 cm x 7.2 cm / 90 g
-20 °C
45 °C
Brand: Philips
