Philips Hue Go 2.0
Philips Hue Go 2.0
Quicklinx: FG2BWS00 Mfr#: 915005822001
Type: Desk lamp
Compatible With: Alexa, Siri, Google Assistant, IFTTT
£58.33 ex VAT
£69.99 inc VAT
Portable Smart Lighting - With its built-in rechargeable battery, take your smart light wherever you go. Use go as the centrepiece for a romantic dinner, or take it outdoors to create that perfect party ambiance. Enjoy from 2.5 hours of brilliant smart lighting and up to 18 hours using the 'cosy candle' Light effect
Control your lights from the Hue Go - Press the button on the portable smart light to choose from seven different light effects - Cool energising daylight, warm relaxing light, and the five dynamic light effects, or tap and hold the button to quickly cycle through colours
Control Lights With Your Voice - Works with all Echo smart speakers/displays and Google Nest devices for hands-free voice control
  • On-product control
    Change your light settings directly with the button on the back of the Hue Go. Simple press sequences allow you to cycle through different light settings or use the pre-set dynamic lighting effects, including the specially designed light recipes Read, Relax, Concentrate and Energize.
  • Dynamic, natural lighting effects
    Use dynamic light effects, such as Cozy Candle, Sunday Coffee, Meditation, Enchanted Forest and Night Adventure to create the perfect mood in any situation.
  • Create a personalized experience with colorful smart light
    Transform your home with over 16 million colors, instantly creating the right atmosphere for any event. With the touch of a button, you can set a festive mood for a party, turn your living room into a movie theater, enhance your home decor with color accents, and much more.
  • Smart lights to wake you up and help you sleep
    Connect your Hue Go to the Hue Bridge and let your lights mimic the sunrise in the morning with the wake up routine, which slowly brightens your lights at a pre-set time to help you start your day feeling calm and refreshed. In the evening, set a go to sleep routine, which gradually dims warm white lights and helps you prepare for a good night's sleep.
  • Set the right mood with warm to cool white light
    These bulbs and light fixtures offer different shades of warm to cool white light. With complete dimmability from bright to low nightlights, you can tune your lights to the perfect shade and brightness of light for your daily needs.
  • Get the perfect light recipes for your daily activities
    Make your day easier and more pleasant with four pre-set light recipes handcrafted especially for your daily tasks: Energize, Concentrate, Read and Relax. The two cool-toned scenes, Energize and Concentrate, help you get going in the morning or keep your focus, while the warmer scenes of Read and Relax help support comfortable reading or calm a busy mind.
  • Control lights with your voice
    Get hands-free control of your lights and use your voice instead! Simple voice commands allow you to control multiple lights in a room or just a single lamp.
Philips Hue Go - desk lamp - LED - 6 W - white
Desk lamp
Light Source Type
LED
White
Wattage
6 W
Luminous Power
520 lumens
Dimmable
Intelligent Assistant
Google Assistant, Alexa
Communications Technology
Bluetooth, Zigbee
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Desk lamp
Built-in battery
Light Source
LED
Wattage
6 W
Luminous Power
520 lumens
Dimmable
Lifetime
20000 hours
Voice control
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Bluetooth, Zigbee
Product Material
Synthetics
Body Colour
White
UK power plug
IP20
United Kingdom
Warranty
2 years
15 cm
7.9 cm
Length
15 cm
625 g
Type: Desk lamp
Compatible With: Siri
Compatible With: IFTTT
Brand: Philips
