With 500 smart mini LEDs along a 40-metre cord, Festavia string lights are the perfect indoor and outdoor decoration. Create a gradient of colour along the string, set an effect such as Sparkle or Prism, or use one shade of white or colour to create a more traditional look.
                Control your wayUse the Hue app, your voice or smart accessories to control your string lights.
                Indoors and outdoorsFestavia string lights are weatherproof, so they can be used both inside your home or outside all year round. And because it's low-volt compatible, you can connect it to the same power supply unit as your other outdoor lights.
                Special string light stylesOnce you've set your scene, make it unique! Use the Linear style for a gradient of color in a single line, Scattered for a random arrangement of color or Mirrored to mirror the colors from the middle of the string.
                Set the sceneBeyond the special holiday scenes that make that time of the year extra festive, any scene from the Hue scene gallery looks beautiful on Festavia - making for perfect year-round decor.
- Philips Hue White and Color Ambiance Festavia - string lights - LED - 28 W - 2000-6500 K - black
- Product Type
- String lights
- Light Source Type
- LED
- Dimmer
- Black
- Wattage
- 28 W
- Colour Temperature
- 2000-6500 K
- Number of LEDs
- 500
- LEDs Pitch
- 80 mm
- Intelligent Assistant
- Siri, Alexa, Google Assistant
- Platform
- Hue
- Communications Technology
- Bluetooth, Zigbee
- Voltage Required
- AC 220 - 240 V
- Frequency Required
- 50 - 60 Hz
- Product Type
- String lights
- Dimmer
- Indoor/outdoor usage, music sync, app-controlled, voice control, weatherproof, colour changeable, protection class ll
Light Source
- LED
- Built-in LED Lamp
- Wattage
- 28 W
- 2000-6500 K
- Number of LEDs
- 500
- LEDs Pitch
- 80 mm
- Lifetime
- 15000 hours
Power Requirements
- Voltage Required
- AC 220 - 240 V
- 50 - 60 Hz
- Power Consumption Stand by
- 0.5 Watt
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Platform
- Hue
- Compatible Application
- Philips Hue App
- Bluetooth, Zigbee
- Product Material
- Synthetics
- Body Colour
- Black
- Cable Colour
- Black
- Included Accessories
- Power adapter
- Warranty
- 2 years
- Length
- 40 m
- 1.8 kg
- Dimensions & Weight Details
- LED diameter: 5 mm
- Shipping Dimensions (WxDxH) / Weight
- 11.4 cm x 40.8 cm x 16.1 cm / 2.48 kg
- -20 °C
- 40 °C
