With 500 smart mini LEDs along a 40-metre cord, Festavia string lights are the perfect indoor and outdoor decoration. Create a gradient of colour along the string, set an effect such as Sparkle or Prism, or use one shade of white or colour to create a more traditional look.
Control your way
Use the Hue app, your voice or smart accessories to control your string lights. -
Indoors and outdoors
Festavia string lights are weatherproof, so they can be used both inside your home or outside all year round. And because it's low-volt compatible, you can connect it to the same power supply unit as your other outdoor lights. -
Special string light styles
Once you've set your scene, make it unique! Use the Linear style for a gradient of color in a single line, Scattered for a random arrangement of color or Mirrored to mirror the colors from the middle of the string. -
Set the scene
Beyond the special holiday scenes that make that time of the year extra festive, any scene from the Hue scene gallery looks beautiful on Festavia - making for perfect year-round decor.
- Philips Hue White and Color Ambiance Festavia - string lights - LED - 28 W - 2000-6500 K - black
- Product Type
- String lights
- Light Source Type
- LED
- Dimmer
- Black
- Wattage
- 28 W
- Colour Temperature
- 2000-6500 K
- Number of LEDs
- 500
- LEDs Pitch
- 80 mm
- Intelligent Assistant
- Siri, Alexa, Google Assistant
- Platform
- Hue
- Communications Technology
- Bluetooth, Zigbee
- Voltage Required
- AC 220 - 240 V
- Frequency Required
- 50 - 60 Hz
- Product Type
- String lights
- Dimmer
- Indoor/outdoor usage, music sync, app-controlled, voice control, weatherproof, colour changeable, protection class ll
Light Source
- LED
- Built-in LED Lamp
- Wattage
- 28 W
- 2000-6500 K
- Number of LEDs
- 500
- LEDs Pitch
- 80 mm
- Lifetime
- 15000 hours
Power Requirements
- Voltage Required
- AC 220 - 240 V
- 50 - 60 Hz
- Power Consumption Stand by
- 0.5 Watt
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Platform
- Hue
- Compatible Application
- Philips Hue App
- Bluetooth, Zigbee
- Product Material
- Synthetics
- Body Colour
- Black
- Cable Colour
- Black
- Included Accessories
- Power adapter
- Warranty
- 2 years
- Length
- 40 m
- 1.8 kg
- Dimensions & Weight Details
- LED diameter: 5 mm
- Shipping Dimensions (WxDxH) / Weight
- 11.4 cm x 40.8 cm x 16.1 cm / 2.48 kg
- -20 °C
- 40 °C
