Philips Hue Festavia string lights 250 LEDs 20-metre
Quicklinx: HWZFWS00 Mfr#: 929003674403
Type: String lights
Compatible With: Siri, Alexa, Google Assistant
Select:
Hurry, only 1 left in stock!
£166.66 ex VAT
£199.99 inc VAT
Express delivery Order within the next 24 hours for delivery on Tuesday
With 250 smart mini LEDs along a 20-metre cord, Festavia string lights are the perfect indoor and outdoor decoration. Create a gradient of colour along the string, set an effect such as Sparkle or Prism, or use one shade of white or colour to create a more traditional look.
  • Control your way
    Use the Hue app, your voice or smart accessories to control your string lights.
  • Indoors and outdoors
    Festavia string lights are weatherproof, so they can be used both inside your home or outside all year round. And because it's low-volt compatible, you can connect it to the same power supply unit as your other outdoor lights.
  • Special string light styles
    Once you've set your scene, make it unique! Use the Linear style for a gradient of color in a single line, Scattered for a random arrangement of color or Mirrored to mirror the colors from the middle of the string.
  • Set the scene
    Beyond the special holiday scenes that make that time of the year extra festive, any scene from the Hue scene gallery looks beautiful on Festavia - making for perfect year-round decor.
Philips Hue White and Color Ambiance Festavia - string lights - LED - 14 W - white/colour - 2000-6500 K - black
String lights
Light Source Type
LED
Dimmer
Wattage
14 W
Colour of Illumination
White/colour
Colour Temperature
2000-6500 K
Number of LEDs
250
LEDs Pitch
80 mm
Intelligent Assistant
Platform
Hue
Communications Technology
Bluetooth, Zigbee
AC 220 - 240 V
Frequency Required
50 - 60 Hz
String lights
Dimmer
Indoor/outdoor usage, music sync, app-controlled, voice control, weatherproof, colour changeable, protection class ll
Light Source
LED
Built-in LED Lamp
Wattage
14 W
White/colour
Colour Temperature
2000-6500 K
Number of LEDs
250
LEDs Pitch
80 mm
Lifetime
15000 hours
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Power Consumption Stand by
0.5 Watt
Internet of Things (IoT)
Platform
Hue
Compatible Application
Philips Hue App
Bluetooth, Zigbee
Product Material
Synthetics
Body Colour
Cable Colour
Power adapter
Warranty
2 years
Length
20 m
1.16 kg
Dimensions & Weight Details
LED diameter: 5 mm
11.4 cm x 27.6 cm x 16.1 cm / 1.7 kg
-20 °C
Type: String lights
Compatible With: Alexa
Brand: Philips
