Philips Hue Econic Pedestal - Black 1x15W
Quicklinx: GVRHWS00 Mfr#: 915005732501
Now expand Hue to your outdoors. The Econic pedestal light can be connected to your existing Hue bridge to enjoy all benefits e.g. away-from-home control and scheduling, and to create any ambience.
  • Special occasions
    Family or friends coming over? Set your outdoor lights to match the occasion. Whether it's a cozy dinner on the balcony, a BBQ on the patio or party in the back garden, you can add a touch of magic to every get-together with Philips Hue. Create colorful scenes or slow-moving dynamic effects to enjoy these special moments to the fullest.
  • Warm to cool white light
    Extend your evenings with Philips Hue outdoor lighting. Set the right ambience on your patio, balcony or porch and relax. From the warm white light of a summer sun, to the ice cool daylight of winter: you can enjoy any shade of white light to fit your mood throughout the year.
  • Control it your way
    Connect your Philips Hue lights with the Bridge and start discovering the endless possibilities. Control your lights from your smartphone or tablet via the Philips Hue app, or add the indoor switches to your system to change your lights. Set timers, notifications, alarms and more for the full Philips Hue experience. Philips Hue even works with Amazon Alexa, Apple Homekit and the Google Assistant to allow you to control your lights with your voice.
  • Paint your outdoors
    With Philips Hue outdoor lighting, there's no limit to the magic you can add. Play with 16 million colors and all shades of white light to create the effect you want. Highlight objects, trees or pathways to make your space stand out. Use the Hue app to save your favorite light settings and recall them whenever you want with the tap of a finger.
  • Set timers for convenience
    Enjoy longer evenings outside, finish gardening or just put the rubbish outside after sunset. Have your Philips Hue lights turn on automatically by setting schedules or use the sunset/sunrise routine. And of course, you can also turn off or dim your lights this way. You'll never have to worry whether you've left any lights on.
Philips Hue Econic - pedestal light - LED light bulb - 15 W - 2000-6500 K - black
Pedestal light
Light Source Type
LED light bulb
Supported Light Bulbs Qty
1
Dimmer
Wattage
15 W
Wattage Equivalent
79 W
Energy Efficiency Class
A
Colour Temperature
2000-6500 K
Luminous Power
1150 lumens
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Pedestal light
1
Supported Light Bulb Wattage
15 W
Compatible Light Bulb Energy Class
A, B, C, D, E, A+
Dimmer
Light Source
LED light bulb
Wattage
15 W
Wattage Equivalent
79 W
A
Colour Temperature
2000-6500 K
Luminous Power
1150 lumens
Lifetime
25000 hours
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Product Material
Metal, glass
Body Colour
IP44
Warranty
2 years
16.3 cm
32.2 cm
Length
16.3 cm
1.5 kg
20.7 cm x 20.7 cm x 37 cm / 1.779 kg
