Philips Hue E27 Starter Kit UK *V2
Quicklinx: BZCVWS00 Mfr#: 929001142002
Connected to you. Get started with the Philips Hue white and color ambiance starter kit and experience high quality white and colored light that offers you endless possibilities. Play with light and choose from 16 million colors in the Hue app to match the light to your mood. Use a favorite photo and re-live that special moment with splashes of light. Save your favorite light settings and recall them whenever you want with the tap of a finger.Set the right ambience for any moment with a range of beautiful, natural white light. Use the app to set any shade of white light, from cool energizing daylight to relaxing warm white light. Take control and set the ambiance. Not too bright. Not too dark. Just right.
Ease your sleeping routine and wake up gently for a fresh start of each day. Philips Hue will help get you out of bed in a nice way. The gradually increasing light intensity gives you the feeling you are waking up naturally with sunlight - rather than the rude awakening of an alarm ringing.
Extend your TV viewing experience to the whole room or lift your gaming experience to the next level. Download a third party app and discover the amazing things you can do with Philips Hue. Or sync light to your favorite music and enjoy every beat to the fullest. Turn any room into a dance floor and see how light reacts to your music. Download one of the third party apps and get the party started with Philips Hue.
You can control your lights remotely wherever you are. Check if you have forgotten to switch your lights off before you left your home, and switch them on if you are working late. With geofencing technology, your lights can even welcome you home or switch off automatically when you leave your home. It’s all about simplifying your life and giving you peace of mind in smart and useful ways.
  • Sync with music and movies
    Extend your TV viewing experience to the whole room or sync light to your favorite music and see how light reacts to the rhythm.
  • Wake up naturally
    Philips Hue will help get you out of bed the way you like it, helping you start your day feeling refreshed. The light brightness increases gradually mimicking the effect of sunrise and helps you wake up naturally, instead of being woken up by the loud sound of an alarm clock.
  • Create your ambiance
    Set the right ambiance for any moment and decorate your home with warm to cool light.
Philips Hue Starter Kit - wireless lighting set - LED light bulb x 3 - shape: A60 - E27 - 9 W - total: 27 W - 16 million colours - 2000-6500 K
Wireless lighting set
Light Source Type
3 x LED light bulb
Supported Light Bulbs Qty
50
Total Wattage
27 W
Dimmer
Shape
A60
Socket Type
E27
Wattage
9 W
Colour of Illumination
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
806 lumens
Beam Angle
160 degree(s)
Dimmable
AC 100 - 240 V
Frequency Required
50 - 60 Hz
50
Total Wattage
27 W
Dimmer
Android compatible, iOS compatible
Light Source
3 x LED light bulb
Shape
A60
Socket Type
E27
Wattage
9 W
16 million colours
Colour Temperature
2000-6500 K
Luminous Power
806 lumens
Beam Angle
160 degree(s)
Dimmable
Lifetime
25000 hours
Upgradable firmware, instant full light
Power Requirements
AC 100 - 240 V
Frequency Required
50 - 60 Hz
Power adapter, wireless bridge, network cable
Warranty
2 years
Dimensions & Weight Details
Wireless bridge height: 2.5 cm x diameter: 10 cm , Light bulb height: 11 cm x diameter: 6.2 cm
