Philips Hue Discover Floodlight
Quicklinx: GQV3WS00 Mfr#: 915005731401
Type: Floodlight
Compatible With: Alexa
£130.05 ex VAT
£156.06 inc VAT
Now expand Hue to your outdoors. The Discover Floodlight can be connected to your existing Hue bridge to enjoy all features to truly welcome you home. With millions of color options you can also create any ambiance.
  • Special light for special occasions
    Holiday cheer starts here - with smart light! Use your Philips Hue lights to transform your home into a festive experience: bright reds and greens for Christmas, subtle pastels for spring or even an eerie purple glow to create the most haunted house on the street at Halloween.
  • Unwind with warm to cool white light
    Extend your evenings with Philips Hue outdoor lighting. Set the right ambience on your patio, balcony or porch and relax. From the warm white light of a summer sun to the ice cool daylight of winter: you can enjoy any shade of white light to fit your mood throughout the year.
  • Control it your way
    Connect your Philips Hue lights with the Bridge and start discovering the endless possibilities. Control your lights from your smartphone or tablet via the Philips Hue app or add the indoor switches to your system to change your lights. Set timers, notifications, alarms and more for the full Philips Hue experience.
  • Paint your outdoors with 16 million colors
    With Philips Hue outdoor lighting, there's no limit to the magic you can add. Play with 16 million colors and all shades of white light to create the effect you want. Highlight objects, trees or pathways to make your space stand out. Use the Hue app to save your favorite light settings and recall them whenever you want with the tap of a finger.
  • Set timers for your convenience
    Enjoy longer evenings outside, finish the gardening or just take the rubbish out after sunset. Have your Philips Hue lights turn on automatically by setting schedules or using the sunset/sunrise routine. And of course, you can also turn off or dim your lights this way. You'll never have to worry whether you've left any lights on.
  • Weather-proof (IP44)
    This Philips Hue outdoor fixture is specially designed for use in outdoor environments and has undergone rigorous tests to ensure its performance. The IP level is described by two figures: the first one refers to the protection level against dust, the second against water. This lamp is designed with IP44: it is protected against water splashed from any direction, making it ideal for general outdoor use.
  • High-quality aluminum and superior synthetics
    The products are specifically designed for outdoor use, employing high-quality materials to ensure optimal performance in outdoor conditions, as well as smart material usage to optimize radio frequency.
  • Powerful light
    This Philips Hue light possesses an LED light source which illuminates a large portion of your garden. Find the route to your driveway, pathway, front or back door brightly lit up, all with the comfort of the right light. Never lose track of what is happening around your house with this powerful Philips Hue light.
  • Smart control, home and away
    Light up your outdoors and see what's going on outside. By connecting your outdoor lights with the Hue Bridge, you can control them in any way you like. With the Philips Hue outdoor sensor, indoor remote control options, such as the Philips Hue app or using your voice, you can control your outdoor lights. You can set light schedules to mimic your presence. Control your outdoor lighting from the comfort of your home or from any other location.
  • Set your lights to welcome you home
    Experience the comfort of your lights turning on automatically when you arrive and turning off when you leave. Unload your car, enter your house, all with the comfort of the right light. Either use the Philips Hue outdoor sensor or set the Hue app to Home or Away mode to switch on all your lights, or let geolocation do it for you, all without touching a button. It's as easy as that.
Philips Hue White and Color Ambiance Discover - floodlight - LED - 15 W - black
Floodlight
Light Source Type
LED
Dimmer
Wattage
15 W
Luminous Power
2300 lumens
Intelligent Assistant
Alexa - indirect
Platform
Hue
Communications Technology
Zigbee
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Floodlight
Dimmer
Splashproof, outdoor usage
Light Source
LED
Built-in LED Lamp
Wattage
15 W
Luminous Power
2300 lumens
Lifetime
25000 hours
Power Requirements
AC 220 - 240 V
Frequency Required
50 - 60 Hz
Internet of Things (IoT)
Hub Compatibility
Philips Hue Bridge
Platform
Hue
Communications Type
Product-to-product
Zigbee
Alexa
Voice Controlled
Indirect
Product Material
Metal, synthetics
Body Colour
IP44
Warranty
2 years
16 cm
22 cm
15.3 cm
Length
22 cm
1.2 kg
20.6 cm x 26.6 cm x 21.9 cm / 1.45 kg
Type: Floodlight
Brand: Philips
